parallel cellsToCells nearest not working
Old   November 6, 2025, 10:34
Default parallel cellsToCells nearest not working
Albertine is on a distinguished road
I'm trying to perform some remapping between two different topologies.
Is anyone aware of any problem in running parallel using nearest as interpolation method? Even remapping on the same topology is not working (in single core does). It seems that intersection and matching are working both single and parallel.
I want to precise that there are no errors, the process starts and stays forever at this stage:
Creating cellsToCells between source mesh and target mesh region0 using nearest
cellsToCells: Calculating couplings between 990448 source cells and 995332 target cells
in sigle core this step is performed in about 20s.
Thanks!!
Albertine is offline   Reply With Quote
Old   December 11, 2025, 10:27
No clues on this?
Old   December 11, 2025, 13:50
Domenico Lahaye
dlahaye is on a distinguished road
Can you please elaborate on what you are trying to accomplish?
I am lost in translation. Thx.
dlahaye is offline   Reply With Quote
Old   December 11, 2025, 17:57
Thanks for taking time to check my issue.
What I'm trying to do is basically a mapFieldsPar in parallel (decomposed source and decomposed target) using nearest as mapMethod, mainly to reduce the execution time.
I made some tests and managed to use, without any problem, intersection and matching, however the first takes lots of time and the second requires a 1:1 correspondence between cells, that is not my case. Consequently I'm trying to use nearest without success.
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 17:38
[mesh manipulation] Dynamic remeshing (mequite) in parallel not working [foam-extend-4.0] Peter_600 OpenFOAM Meshing & Mesh Conversion 4 August 1, 2017 07:07
parallel finally working hedley SU2 Installation 0 June 23, 2014 12:35
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
parallel fluent under pbs not working kharnabnew FLUENT 0 January 6, 2011 04:28
