Flow not coming out of model
Old   November 7, 2025, 09:50
Default Flow not coming out of model
Cristopher Medina Samanez
stopherkri is on a distinguished road
Hello guys,
I'm trying to model a 3d spillway using the interFoam solver, everything is running smoothly until the point when water reaches the outlet. It seems like it's not flowing out freely, it appers to be bouncing back at the outlet, I'm getting negative outflow at the patch.
Maybe I'm not setting correctly my boundary conditions. Hope you can help me out.
This are my initial conditions
alpha.water
boundaryField
inlet
type fixedValue;
value uniform 1;
outlet
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
walls
type zeroGradient;
U
boundaryField
inlet
type flowRateInletVelocity;
volumetricFlowRate constant 0.015811388;
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
walls
type noSlip;
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
p_rgh
boundaryField
inlet
type fixedFluxPressure;
value uniform 0;
outlet
type totalPressure;
p0 uniform 0;
value uniform 0;
walls
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
value uniform 0;
stopherkri is offline   Reply With Quote
Old   November 7, 2025, 12:49
Michael Häckel
michael_h is on a distinguished road
You have specified zero outlet velocity. If you specify a constant pressure then you need "type zeroGradient" for the U field.
Originally Posted by stopherkri View Post
Hello guys,
outlet
type inletOutlet;
michael_h is offline   Reply With Quote
Old   November 14, 2025, 07:28
M
AtoHM is on a distinguished road
That is not correct, inletOutlet acts as a zeroGradient condition in outflow direction and applies inletValue when backflow happens.
I checked out one of the interFoam tutorials \tutorials\multiphase\interFoam\RAS\waterChannel, It uses fixedFluxPressure for outlet instead of totalPressure.
AtoHM is offline   Reply With Quote
axial compressor mass flow convergence issue jyotir SU2 5 July 5, 2024 10:06
Model of air–steam flow with condensation into the volume and surface wall gartz89 ANSYS 1 February 19, 2022 07:52
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Coupled Flow model RalphS OpenFOAM 1 November 15, 2010 04:51
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
