Issue with simulating a river and its surrounding
Old   November 19, 2025, 06:24
Question Issue with simulating a river and its surrounding
Boris
Hawxliquid is on a distinguished road
Hi everyone!
I am trying to do a simulation of a river and its surrounding. I made an example mesh and you can find the files here : https://www.dropbox.com/scl/fi/nu1k4...=s52n6k84&dl=0
I am using interFoam, but can not get any results. I have several issue, but the main one for now is the weird behaviour of the air part, as seen in the image. There seems to be some kind of weird unstability arising.
Do you have any idea of the BCs I should be using in that case?
Here are the main current ones (to reference to the image, if you do not want to download the example case)
alpha.water (before the setField do define a bit of water at the inlet)
    inlet
        type            variableHeightFlowRate;
        lowerBound      0;
        upperBound      1;
        value           uniform 0;
    walls
        type            zeroGradient;
    outlet
        type            zeroGradient;
        value           uniform 0;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    side_atmosphere
        type            zeroGradient;
        value           uniform 0;
U
    inlet
        type            variableHeightFlowRateInletVelocity;
        flowRate        1;
        alpha           alpha.water;
        value           uniform (0 0 0);
    walls
        type            noSlip;
    atmosphere
        type            pressureInletOutletVelocity;
    side_atmosphere
        type            zeroGradient;
    outlet
        type            zeroGradient;
p_rgh
    atmosphere
        type            totalPressure;
        p0              uniform 0;
    inlet
        type            zeroGradient;
    walls
        type            fixedFluxPressure;
    side_atmosphere
        type            zeroGradient;
    outlet
        type            zeroGradient;
Thanks!
Hawxliquid is offline   Reply With Quote
