simulation works in OF8, but fails in OF2412. Why?
Old   December 15, 2025, 13:37
Default simulation works in OF8, but fails in OF2412. Why?
Alan w
boffin5 is on a distinguished road
Currently I am in the throes of converting my efforts from the .org version of OpenFoam (using OF8) to the .com version (using OF2412).
So, I picked a chtMultiRegionSimpleFoam case to use, which works fine in OF8 to use as a test case. It is a radiator simulation in which flow goes
through a duct in a body, and through a porous region simulating a radiator.
After plodding through all of the syntax and procedural changes, I finally ended up at the point where the code actually executes chtMultiRegionSimpleFoam.
Now, in the process of the prior errors, OF would give me clues as to how to fix the problem. But in this end step, the result is baffling (for me, anyway):
Create time
Create fluid mesh for region fluid for time = 0
Create fluid mesh for region porous for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package
    type            heRhoThermo;
    mixture         pureMixture;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
    energy          sensibleEnthalpy;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to hRefFluid
    Adding to ghFluid
    Adding to ghfFluid
    Adding to turbulenceFluid
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
    RASModel        kEpsilon;
    turbulence      on;
    printCoeffs     on;
    Cmu             0.09;
    C1              1.44;
    C2              1.92;
    C3              0;
    sigmak          1;
    sigmaEps        1.3;
    Adding to reactionFluid
Combustion model not active: combustionProperties not found
Selecting combustion model none
    Adding to radiationFluid
Selecting radiationModel none
    Adding to KFluid
    Adding to dpdtFluid
    Adding to fieldsFluid
    Adding to QdotFluid
pressureControl
    pMax 169118
    pMin 8455.9
    Adding MRF
No MRF models present
    Adding fvOptions
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options type constantHeatTransfer
    Source: fluidToporous
Selecting finite volume options type interRegionExplicitPorositySource
    Source: porosityBlockage
- selecting inter region mapping
Creating mesh-to-mesh addressing for fluid and porous regions using cellVolumeWeight
    Overlap volume: 0.00189348
*** Reading fluid mesh thermophysical properties for region porous
    type            heRhoThermo;
    thermo          hPolynomial;
    specie          specie;
    Adding to rhoFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to hRefFluid
    Adding to ghFluid
    Adding to ghfFluid
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Radiation model not active: radiationProperties not found
    Adding to KFluid
    Adding to dpdtFluid
    Adding to QdotFluid
pressureControl
    pMax 200000
    pMin 10000
    Adding MRF
    Adding fvOptions
    Source: porousToair
Creating mesh-to-mesh addressing for porous and fluid regions using cellVolumeWeight
    Overlap volume: 0.00189334
Region: fluid Courant Number mean: 0.313316 max: 5195.38
Region: porous Courant Number mean: 1.77951 max: 9.7342
Time = 1
[stack trace]
#1  Foam::sigFpe::sigHandler(int) in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2  ? in /lib/x86_64-linux-gnu/libc.so.6
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#4  Foam::operator/(Foam::UList<double> const&, Foam::UList<double> const&) in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#5  Foam::diagonalSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
#7  ? in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
#8  Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so
#9  ? in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam
#10  ? in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam
#11  ? in /lib/x86_64-linux-gnu/libc.so.6
#12  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#13  ? in /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam
[DESKTOP-L9QTPS2:4075 :0:4075] Caught signal 8 (Floating point exception: tkill(2) or tgkill(2))
==== backtrace (tid:   4075) ====
 0  /lib/x86_64-linux-gnu/libucs.so.0(ucs_handle_error+0x2ec) [0x7759c0312f2c]
 1  /lib/x86_64-linux-gnu/libucs.so.0(+0x3530d) [0x7759c031430d]
 2  /lib/x86_64-linux-gnu/libucs.so.0(+0x3572a) [0x7759c031472a]
 3  /lib/x86_64-linux-gnu/libc.so.6(+0x458d0) [0x7759c0a458d0]
 4  /lib/x86_64-linux-gnu/libc.so.6(pthread_kill+0x11c) [0x7759c0aa49bc]
 5  /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x1e) [0x7759c0a4579e]
 6  /lib/x86_64-linux-gnu/libc.so.6(+0x458d0) [0x7759c0a458d0]
 7  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_+0x6a) [0x7759c1859e8a]
 8  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4FoamdvERKNS_5UListIdEES3_+0x74) [0x7759c185bbd4]
 9  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZNK4Foam14diagonalSolver5solveERNS_5FieldIdEERKS2_h+0x4b) [0x7759c16d7d3b]
10  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE15solveSegregatedERKNS_10dictionaryE+0xb8f) [0x7759c648025f]
11  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(+0x54b5e2) [0x7759c5f4b5e2]
12  /usr/lib/openfoam/openfoam2412/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZNK4Foam6fvMesh5solveERNS_8fvMatrixIdEERKNS_10dictionaryE+0x28) [0x7759c5f3a468]
13  chtMultiRegionFoam(+0x69a74) [0x63052331ba74]
14  chtMultiRegionFoam(+0x34406) [0x6305232e6406]
15  /lib/x86_64-linux-gnu/libc.so.6(+0x2a578) [0x7759c0a2a578]
16  /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x8b) [0x7759c0a2a63b]
17  chtMultiRegionFoam(+0x43b45) [0x6305232f5b45]
I really don't have a clue as to why it fails, especially since it worked okay in OF8, and I can't really decipher what the error message says.
But I know that in this community there are people who can, and I hope that they might be able to offer some advice. I can certainly provide the case files if someone can have a look.
boffin5 is offline   Reply With Quote
Old   December 15, 2025, 14:32
Default boundary conditions
Alan w
I'm sorry, I should have included the boundary conditions, so here they are.
btw, the body is in free space, with no external walls around the domain.
For the body with duct:
Boundary Conditions for Fluid
T
internalField   uniform 551.55;
boundaryField
    frontier
        type            zeroGradient;
    inlet
        type            fixedValue;
        value           uniform 551.55;
    outlet
        type            inletOutlet;
        inletValue      uniform 551.55;
    bod {
        type            zeroGradient;
U
internalField   uniform (90 0 0);
boundaryField
    frontier
        type            slip;
    inlet
        type            fixedValue;
        value           uniform (5 0 0);
     bod {
        type            fixedValue;
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
alphat
internalField   uniform 0;
boundaryField
    frontier
        type            slip;
        value           uniform 0;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    bod
        type            compressible::alphatWallFunction;
        value           uniform 0;
epsilon
internalField   uniform 0.54;
boundaryField
    frontier
        type            slip;
    inlet
        type            fixedValue;
        value           $internalField;
    outlet
        type            zeroGradient;
    bod
        type            epsilonWallFunction;
k
internalField   uniform 0.375;
boundaryField
    frontier
        type            slip;
    inlet
        type            fixedValue;
    outlet
        type            zeroGradient;
    bod
        type            kqRWallFunction;
nut
boundaryField
    frontier
        type            slip;
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    bod
        type            nutkWallFunction;
        value           uniform 0;
p
internalField   uniform 84559;
boundaryField
    frontier
        type            slip;
    inlet
        type            calculated;
        value           uniform 84559;
    outlet
        type            calculated;
    bod
        type            calculated;
p_rgh
boundaryField
    frontier
        type            slip;
    inlet
        type            fixedFluxPressure;
    outlet
        type            fixedValue;
    bod
And for the porous body:
Boundary Conditions for Porous Body
T
internalField   uniform 350;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 400;
    outlet
        type            inletOutlet;
        inletValue      uniform 350;
        value           uniform 350;
    frontier
        type            zeroGradient;
    rad_radinlet {
        type            fixedValue;
    rad_radoutlet {
        type               inletOutlet;
        inletValue      $internalField;
     rad_radfrontier {
        type            zeroGradient;
U
internalField   uniform (0.01 0 0);
boundaryField
    frontier
        type            slip;
    inlet
        type            fixedValue;
    outlet
        type            inletOutlet;
    rad_radinlet
        type            calculated;
    rad_radoutlet
        type            calculated;
    rad_radfrontier
        type            noSlip;
p
internalField   uniform 100000;
boundaryField
    frontier
        type            zeroGradient;
     inlet
        type            zeroGradient;
    outlet
        type            calculated;
    rad_radinlet
        type            calculated;
    rad_radoutlet
        type            calculated;
    rad_radfrontier
        type            zeroGradient;
p_rgh
boundaryField
    frontier
    inlet
    outlet
        type            fixedValue;
        value           uniform 100000;
    rad_radinlet
    rad_radoutlet
     rad_radfrontier
Old   December 16, 2025, 07:56
Tobermory will become famous soon enough
This will take some time to untangle, but let me just parse the output error for you - that may point you in the right direction to solve it.
The stack trace shows that the code fell over with a SIGFPE (floating point error) from a divide operation - usually a divide by zero error. This occurred in the diagonal solver, right at the start of the first time step ... so I guessing that this was when solving for the density field. So - that's your starting point.
Looking at your BC's - you have "type slip" for all variables on patch "frontier" ... that's clearly a typo. Not sure why this would give a divide by zero error, but please check you boundaries and then try again.
Good luck!
Tobermory is offline   Reply With Quote
Old   December 16, 2025, 09:34
Smile
nee
Neeraj
nee is on a distinguished road
If it is working with of8 then work on that and make further changes with that , There is no need to stitch with the versions , All we need to solve the problems in hand
nee is offline   Reply With Quote
Old   December 16, 2025, 12:55
I understand your sentiment, but I am not sure that your comment is very helpful to the OP ... there may be a good reason why he needs to change version. For example, whilst I tend to stick to the Foundation fork of OpenFOAM, I do use the .COM fork when I need access to different snappyHexMesh parameters, or to some of the turbulence models that are present only in the ESI fork.
Old   December 16, 2025, 14:00
Default Why I changed, and further question
Alan w
Thank you nee and Tobermory,
First, why I changed:
After running OpenFoam for a long time, my linux emulator (VMware) irreparably died, so I decided to change to wsl/ubuntu. Getting things working took quite a while, and I decided to go to an up-to-date version of OpenFoam. In the .org world, this was OF11, which had changed to a modular approach. Getting my head around this was going to be another challenge, so I opted for the current .com version, which is 2412.
Concerning Tobermory's comment on my slip boundary condition:
I am (obviously) thoroughly confused by BCs. For this case, involving a body in open free stream, I looked at the motorBike tutorial. In this one, the domain boundaries for U are given in an #include file, 'frontBackUpperpatches. The BC for this one is given as slip. They have the same condition in U, p and omega.
But apparently this doesn't apply to my body-with-a-duct in open air. So I keep fishing and trying.
Old   December 17, 2025, 06:43
You're absolutely right Alan - apologies: "slip" is fine to use for all of the fields (it's essentially just the same as a symmetryPlane boundary condition) ... I had never seen it used on anything other than the U field, and was confusing it with the "noSlip" condition which is clearlyonly for U.
Old   December 17, 2025, 15:13
Default It keeps failing and I am stumped
Alan w
Hi Everyone,
This case is comprised of a simple blocky shape with a duct and porousbody/heat exchanger, and it's meant to form the basis of more detailed studies. I had it running at one time in OF8, but despite my efforts at iterating the boundary conditions, it keeps failing immediately in 2412.
So I am getting on my knees and hoping that someone can have a look at the zip file and help find the error. It's a simple simulation, and the well initiated in the community should cut through it like the proverbial knife through butter. But I don't want to minimize the difficulty, and would just be thankful for any help that I might be fortunate enough to receive.
[snappyHexMesh] snappyHexMesh fails but Fluent mesh works ? Kummi OpenFOAM Meshing & Mesh Conversion 2 June 13, 2024 06:29
CFG file Set Up Nicola_Fontana SU2 5 November 16, 2021 13:48
kEpsilon simulation works with a reynolds number of 1e6 but not 5e4 kodexys OpenFOAM Running, Solving & CFD 0 August 3, 2016 13:00
FSI TWO-WAY SIMULATION Smagmon CFX 1 March 6, 2009 14:24
CFX FAQ updated - my simulation fails to converge Glenn Horrocks CFX 0 September 1, 2007 08:33
