Finally got my aircraft radiator case to run, but weird results
Old   January 14, 2026, 16:11
Default Finally got my aircraft radiator case to run, but weird results
Alan w
boffin5 is on a distinguished road
After a bit of effort, I have my aircraft heat exchanger simulation running.
But, the results don't seem to make sense. Attached is an image of the T field,
with some representative air temperatures in front of the HX, and behind it.
As can be seen, the air temperature in front of the HX is 2 degrees hotter than the air temperature behind it. This doesn't make sense, as the heated air should be coming out of the radiator, behind it.
I am attaching some relevant files for those who might be interested, including the p and T files for the fluid and porous zones. Also the constant/fluid/fvOptions file, which defines the porosity of the porous zone.
Note in my simulation, the longitudinal axis is along the Y direction, with the X axis coming out of the screen. This caused me some confusion with the fvOptions e1 and e2 variables. But I think(?) I have it right.
Here is the fvOptions file:
fluidToporous
    type            constantHeatTransfer;
    interpolationMethod cellVolumeWeight;
    nbrRegion       porous;
    master          false;
    nbrModel        porousTofluid;
    fields          (h);
    semiImplicit    no;
porosityBlockage
    type            interRegionExplicitPorositySource;
    interRegionExplicitPorositySourceCoeffs
        nbrRegion       porous;
        type            DarcyForchheimer;
        // D 100;  // Very little blockage
        // D 200;  // Some blockage but steady flow
        // D 500;  // Slight waviness in the far wake
        // D 1000; // Fully shedding behavior
        d   (400  400  100);
        f   (400  400  100);
        coordinateSystem
            origin  (0 0 0);
            e1      (0 -1 0);    // (0 -1 0)
            e2      (1 0 0);     // (1 0 0)
The T and p BC files for the fluid zone:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 272.3;
boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    frontier
        type            slip;
    inlet
        type            fixedValue;
        value           uniform 272.3;
    outlet
        type            inletOutlet;
        inletValue      uniform 272.3;
    "fuselage|duct|lips|rad-fairing"
        type            zeroGradient;
    centerline
        type            symmetry;
|  \\    /   O peration     | Version:  v2412                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 75300;
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           $internalField;
    frontier
        type            slip;
        type            zeroGradient;
    centerline
        type            symmetry;
And for the porous zone:
FoamFile
    version     2.0;
    format      ascii;
    object      T;
internalField   uniform 383;
boundaryField
    radinlet
        type            fixedValue;
    radoutlet
        type            inletOutlet;
        inletValue      uniform 383;
        value           uniform 383;
    rad_radfrontier
        type            zeroGradient;
    rad_radcenterline
        type            symmetry;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    radinlet
        type            zeroGradient;
    radoutlet
        type            zeroGradient;
    rad_radfrontier
        type            zeroGradient;
   rad_radcenterline
        type            symmetry;
The ambient air temperature is 272.3 deg K, and for the porous zone T is 383 deg K. The aircraft speed is 84.88 meters per second.
Hopefully with help, I can solve this mystery!
File Type: png SnapCrab_NoName_2026-1-14_11-51-34_No-00.png (81.6 KB, 18 views)
boffin5 is offline   Reply With Quote
Old   January 15, 2026, 09:03
Domenico Lahaye
dlahaye is on a distinguished road
No clue, sorry to say.
I, however, wonder.
Does it make sense here to run an adiabatic case (without the solid) and subsequently run a case in which the presence of the solid is modeled using boundary conditions?
dlahaye is offline   Reply With Quote
Old   January 15, 2026, 12:10
Tobermory will become famous soon enough
It looks to me that the rise in temperature upstream of the HX is due to the flow decelerating in the diffuser just upstream of the HX (which, with a compressible equation of state leads to a pressure rise and small temperature rise) ... you can see the same effect, and same deltaT, in other parts of the picture where the flow is decelerating, and the opposite (a cooling) in the nozzle downstream of the HX where the flow is accelerating.
My suspicion is that the HX heat source is not active ...?
Tobermory is offline   Reply With Quote
Old   January 15, 2026, 12:19
I am not familiar with prorous zone modelling, or how your two zones interact, but one quick observation on your porous zone boundary:
    radoutlet
        type            inletOutlet;
        value           uniform 383;
I don't think that this is doing what you think it is. By default, if the flow is exiting the porous zone through this boundary, then the temperature on the boundary will be governed by the temperature of the fluid that enters the boundary ... i.e. the upstream fluid, at 272K. The inletValue of 383K is only used if there is reverse flow INTO the porous zone through the outlet boundary ... which I am assuming is not the case. The "value" part of the boundary is ignored (in fact, if you look at your solution, in the T file you will find that this value has been updated with the latest calculated boundary T value .. which is probably 272K!). This explains why the outlet temperature from the HX is 272K.
So, long and short of it - you can't inject heat into the porous region using an inletOutlet outlet condition ... you need to either do it at the inlet to the porous region, or using a volume source.
Hope that helps.
Visualizing Aircraft CFD results in Virtual Reality mihaipruna Main CFD Forum 2 March 10, 2020 18:39
Weird results with small time steps Zackzack FLUENT 0 July 10, 2018 07:54
Weird velocity results for low mach number combustion Rafael Meier OpenFOAM Running, Solving & CFD 0 June 8, 2018 12:36
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
intermediate results during a transient run Michael Skoblin CFX 1 September 25, 2006 15:00
