March 5, 2009, 12:20 |
Hello World.
I tried to run
Sebastian Gatzka
Rep Power: 20 |
Hello World.
I tried to run an interDyMFoam case in parallel. I first run the decomposePar and split the domain into two. After running mpirun -np 2 interDyMFoam -parallel >log there is this entry in the log-file: DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 [0] #0 Foam::error::printStack(Foam:: Ostream&) and still one processor is running interDyMFoam. What went wrong? BTW I'm using a 64bit machine.
Schrödingers wife: "What did you do to the cat? It's half dead!" |
March 12, 2009, 05:54 |
Meanwhile I got the solver to
Sebastian Gatzka
Rep Power: 20 |
Meanwhile I got the solver to work on two processors, but the computational time is the same as with one processor.
Although the two processors were busy the corresponding processor-directories are empty and the main directory is filled with the final solution directories. I think there is something wrong, but I have no idea what it may be. Maybe I made a mistake splitting the domain (which is containing a cyclic bc)? decomposeParDict
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
Running in parallel | Rasmus Gjesing (Gjesing) | OpenFOAM | 35 | March 31, 2011 18:21 |
InterDyMFoam dynamic messing in parallel fails under nonquiescent conditions | adona058 | OpenFOAM Running, Solving & CFD | 5 | August 19, 2010 11:47 |
Problem in running Parallel | mamaly60 | OpenFOAM Running, Solving & CFD | 1 | April 19, 2010 11:11 |
InterDyMFoam dynamic meshing in parallel fails under nonquiescent conditions | adona058 | OpenFOAM Bugs | 7 | November 18, 2008 14:58 |
