How to solve in simpleFoam with a volumesourceterm implicity |
March 11, 2009, 05:44 |
Hey openFoam experts,
i wan
Rep Power: 17 |
i want to solve the following in openfoam navier-stokes-equation like in simpleFoam, tmp<fvvectormatrix> UEqn ( fvm::div(phi, U) + turbulence->divR(U) ); UEqn().relax(); solve(UEqn() == -fvc::grad(p)-alpha);//sourceterm with alpha and U (velocity of flow) are vector/volVectorFields. My goal is to solve the sourceterm alpha implicity and tried with tmp<fvvectormatrix> UEqn ( fvm::div(phi, U) + turbulence->divR(U) + fvm::Sp(alpha / U, U) // implicit sourceterm ); UEqn().relax(); solve(UEqn() == -fvc::grad(p)); But i get an error like FOAM FATAL ERROR : incompatible fields for operation [U] + [alpha]#0 Foam::error::printStack(Foam::-Ostream&) in "/users/studi8/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" Have someone any idea, how to solve these problem implicity anyway? Regards, Khaled |
March 11, 2009, 06:39 |
problem:
dU/dt = U + a
exp
Niklas Nordin
Rep Power: 29 |
problem:
dU/dt = U + a explicit: (U^n - U^(n-1)/dt = U^(n-1) + a implicit: (U^n - U^(n-1)/dt = U^n + a explicit/implicit has nothing to do with the evaluation of a here, only with how U is evaluated. So your question doesnt make any sense. ...unless a really is a = a(U) but thats not obvious from your question. if the influence of a is big there is a common linearizing 'cheat' that goes something like this: dU/dt = U + a*1 = U + a*(U/U) discretized as: (U^n - U^(n-1)/dt = U^(n-1) + a*(U^n/U^(n-1)) |
March 12, 2009, 02:16 |
...interrupted...continuing:
Niklas Nordin
Rep Power: 29 |
however if a and U is a vector you will have a/U (vector/vector = ?) further (a/U)*U should still be a vector so (a/U) should either be a scalar or a matrix and in your case it is probably a matrix, so you have to construct this matrix, which is probably diagonal and a_i/U_i. And as far as I know there is no implementation of implicit treatment of fvm::Sp(<tensorfield>, <vectorfield>) |
March 12, 2009, 03:17 |
Hi Niklas,
it seems so. Itī
Rep Power: 17 |
Hi Niklas,
it seems so. Itīs a pity. I try it explicit like tmp<fvvectormatrix> UEqn ( fvm::div(phi, U) + turbulence->divR(U) ); UEqn().relax(); solve(UEqn() == -fvc::grad(p)-alpha);//sourceterm Thanks, Khaled |
Display Modes | |
Problems with the RSM in simpleFoam | sberg | OpenFOAM Running, Solving & CFD | 10 | February 25, 2014 19:39 |
What is phi in simpleFoam | ehsan_vaghefi | OpenFOAM Running, Solving & CFD | 7 | September 29, 2013 11:00 |
NACA0012 with simpleFOAM | nuovodna | OpenFOAM Running, Solving & CFD | 7 | May 19, 2010 04:58 |
SimpleFoam error | sven82 | OpenFOAM Running, Solving & CFD | 0 | October 16, 2008 04:13 |
Using simpleFoam with water | nico765 | OpenFOAM Running, Solving & CFD | 7 | October 23, 2007 05:39 |
