SIMPLE loop in interTrackFoam
Old   March 11, 2009, 04:12
Default Hello, I have a question c
Virginie Ehrlacher
virginie_e is on a distinguished road
I have a question concerning the SIMPLE loop in interTrackFoam, especially about the velocity equation.
In interTrackFoam, UEqn is implemented this way:
tmp<fvvectormatrix> UEqn
fvm::ddt(rho, U)
+ fvm::div(phiNet, U)
- fvm::laplacian(mu, U)
UEqn().relax();
solve(UEqn() == - fvc::grad(p));
whereas in other solvers using the SIMPLE algorithm, it is implemented this way:
fvm::ddt(U)
+fvm::div(phi,U)
-fvm::laplacian(nu,U)
UEqn.relax();
solve (UEqn == -fvc::grad(p));
I understand that the difference is that the interTrackFoam equation is the second one multiplied by rho, but in that case, should the second term -fvc::grad(p) not be multiplied by rho as well? so that the equation should become something like:
fvm::ddt(rho, U)
UEqn().relax();
solve(UEqn() == - rho()*fvc::grad(p));
or something like that?
If what I said is wrong, is there something that I misunderstood in the equation solving in OpenFOAM?
Otherwise, how should I write the equivalent of the line
Thank you in advance
virginie_e is offline   Reply With Quote
Old   March 11, 2009, 04:23
Default Hi Virginie If you look at
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Virginie
If you look at 0/p in the hydroFoil test case, then you will see that the pressure has dimensions which differ from those in for instance simpleFoam-tutorials.
Thus rho is incorporated in p.
I hope it did clarify you doubts.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   March 17, 2009, 05:38
Virginie Ehrlacher
Thank you Niels.
Indeed, I had not pointed out that the p dimensions was different. Thank you for your answer, it helped a lot!
Virginie
Old   March 17, 2009, 05:40
Virginie Ehrlacher
just a quick message to say that I resolved my problems. This high pressure is not a divergence, it is the real result. My problems come from the fact that the cells of my mesh become very flat.
Virginie
InterTrackFoam any information rajon OpenFOAM Running, Solving & CFD 30 January 1, 2016 16:27
Wall contact in interTrackFoam virginie_e OpenFOAM Running, Solving & CFD 2 November 8, 2011 11:52
Pressure divergence with interTrackFoam virginie_e OpenFOAM Running, Solving & CFD 8 March 4, 2009 05:07
InterTrackFoam error kester OpenFOAM Running, Solving & CFD 10 November 8, 2007 02:55
loop(p,I->p) how this loop works? Sinan FLUENT 0 January 18, 2005 18:04
