SimpleSRFFoam application usage and experiences
Like Tree1Likes
  • 1 Post By sarahk
Old   September 19, 2008, 16:42
Default I have been using the OF v1.5
Chris Sideroff
cnsidero is on a distinguished road
I have been using the OF v1.5 simpleSRFoam - steady, incompressible, rotating reference frame - solver. Despite their being no documentation any where, I managed to decipher the example case ('mixer') provided and generate a "reasonable looking" solution.
I say reasonable because I have no data and haven't compared the solution to another solvers yet. While I finish up my doctorate, I have access to Fluent - in which I have run this case but yet the compare the solution to OF. One thing I can say OF runs _much_ faster than Fluent.
I wanted to start a thread where others who are using the solver can discuss usages and experiences with it.
One piece I would like to add, is the derived BC type 'surfaceNormalFixedValue' for rotating reference frame applications. For my case (see attached pictures), I had six inlets that I wanted to specify the normal velocity on but all the inlet patches had non-aligned positions and normal orientations. Needless to say it was a pain figuring them out so I could enter the velocity components for each inlet.
Anyone else using this solver please post thoughts/experiences here to share with all.
-Chris
cnsidero is offline   Reply With Quote
Old   September 21, 2008, 12:27
Default Hi Chris may i ask is this pic
Franz
ffbof is on a distinguished road
Hi Chris may i ask is this picture done with the SRF solver ?
ffbof is offline   Reply With Quote
Old   September 22, 2008, 05:09
Default Hello, I tried to compile th
Franz
I tried to compile the simpleSRFFoam by using the backports in the 1.4.1-dev. But i got several errors.
I made it compile by adding the following lines to the make/options file.
-I./SRFModel \
-I./SRFVelocityFvPatchVectorField \
Mr Jasak could you correct that in the repository just for newbies.
Regards
Franz
Old   September 22, 2008, 16:45
Default Hi Franz, thanks for the repli
Chris Sideroff
Hi Franz, thanks for the replies.
Yes, the image I attached is from the solution using the simpleSRFFoam solver. I used VisIt to generate the image.
I have no experiences using simpleSRFFoam with OF v.1.4 - only v1.5 - so I will defer that question to the experts.
You can install v1.4 and v1.5 side-by-side, if that's an option for you.
Good Luck, Chris
Old   October 3, 2008, 23:00
Default Hi Franz: have you ever suc
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi Franz:
have you ever succeed to compile the simpleSRFFoam in OF-1.4.1?
thanks
yours wayne
waynezw0618 is offline   Reply With Quote
Old   June 29, 2010, 11:48
Default Adding Temperature to simpleSRFFoam
Sarah Köhler
sarahk is on a distinguished road
Hey Foamers,
im a newbie with OpenFoam.
Right now i try to add the Temperature to the simpleSRFFoam tutorial mixer.
after some time steps it stops and says "floating point exception".
And paraview shows that the temperature is infinity the whole time.
I think its an error in the initial conditions. But i dont know which one i could use!
Any ideas how to fix this?
Thanks you!
sarah
sarahk is offline   Reply With Quote
Old   September 24, 2010, 04:18
David
David_010 is on a distinguished road
Hi Sarah
I know you have written your post long time ago, but may be you can help me. I am trying to add temperature to the solver simpleSRFFoam. To do that, I have created a new flux, phiAbs, calculated each time loop with the absolute velocity Uabs. Then I use this phiAbs in the temperature equation.
The solver compiles without errors, and the case iterates without problems, but the obtained temperature field corresponds to static conditions. I mean, is like the temperature equations is solved with velocity equal to zero, not with Uabs.
Did you add the temperature to the solver?. Any help will be useful.
Thank you very much
David.
David_010 is offline   Reply With Quote
Old   March 3, 2011, 07:56
Vishal Jambhekar
vishal is on a distinguished road
I know to you it might sound stupid. but what I would like to know that is the difference this one and simplefoam ?? I have also compared results of OF and FLUENT for other type od flow and I found OF little better.
Cheers,
Vishal Jambhekar...
"Simulate the way ahead......!!!"
vishal is offline   Reply With Quote
Old   April 26, 2011, 07:28
JunaidAhmad's Avatar
Junaid Ahmad Khan
JunaidAhmad is on a distinguished road
Hi.
I started to use OF a couple of weeks ago and i try to run the tutorials that are given in OF-1.7.1. and understand a lot with those.
Now i am trying to run mixer tutorial that use simpleSRFFoam so i follow these step:
blockMesh (For Mesh Building)
then i use simpleSRFFoam and i get:
simpleSRFFoam: command not found
can some one identify the problem
Regards
Junaid
JunaidAhmad is offline   Reply With Quote
Old   April 26, 2011, 07:52
Sarah Köhler
Hey,
its possible that you have to make it before.
If there is a Folder called Make, just use wmake and it should build the app into your personal OF Folder.
Greetings,
Sarah
JunaidAhmad likes this.
Old   April 27, 2011, 04:14
Default Thanks
  #11
Junaid Ahmad Khan
Rely appreciate your concern.
Regards
Junaid
Old   April 27, 2011, 04:46
Default HOWTO View Complete Mixer in ParaFoam
  #12
Junaid Ahmad Khan
Dear Sarah,
can you tell me how to view complete rotor of mixer. as it shows only single rotor blade.
Regards,
Junaid
Boundary conditions for simpleSRFFoam cnsidero OpenFOAM Running, Solving & CFD 5 May 17, 2017 11:26
Ploblem using simpleSRFFoam abchavz OpenFOAM Bugs 0 February 7, 2009 12:14
SimpleSRFFoam or MRFFoam waynezw0618 OpenFOAM Running, Solving & CFD 2 December 7, 2008 03:45
Relative velocity in simpleSRFFoam miku OpenFOAM Running, Solving & CFD 4 November 4, 2008 10:51
Building error with simpleSRFFoam and MRFSimpleFOAM in 15 waynezw0618 OpenFOAM Running, Solving & CFD 4 August 27, 2008 10:31
