May 8, 2023, 15:48 |
rhoCentralFoam Case Blowing Up
Sakun
Rep Power: 6 |
Hello everyone,
I am trying to simulate my high-speed single blade simulation in rhoCentralFoam. It is running for couple of iterations and suddenly crash. Error that generate doesn't give much information either. I need to run this case using kOmega SST and i have attached fvSchemes and fvSolution files below. Please someone help me on this issue? Error that generated; Code:
deltaT = 4.11195e-09 Mean and max Courant Numbers = 0.00342632 1.6291 Time = 6.09249e-07 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 4.96493e-05, Final residual = 5.54071e-07, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 5.67593e-05, Final residual = 7.83343e-07, No Iterations 2 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 ? in /lib/x86_64-linux-gnu/libm.so.6 #4 ? at ??:? #5 ? at ??:? #6 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam #7 ? in /lib/x86_64-linux-gnu/libc.so.6 #8 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #9 ? in /usr/lib/openfoam/openfoam2206/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam Floating point exception (core dumped) Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fluxScheme Kurganov; ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(tauMC) Gauss linear; div(phi,U) Gauss Minmod; //div(phi,U) Gauss linearUpwind limitedU; //div(phi,U) Gauss linearUpwindV limitedU; //div(phi,U) Gauss upwind; turbulence1 Gauss linear; turbulence2 Gauss linearUpwind limitedT; turbulence3 Gauss limitedLinear 1; div(phi,k) $turbulence1; div(phi,omega) $turbulence1; energy1 Gauss linearUpwind limitedE; energy2 Gauss limitedLinear 1; energy3 Gauss LUST limitedE; energy4 Gauss linear; div(phi,e) $energy4; //enthalpy -> h div(phi,h) $energy2; div(phi,K) $energy2; //div(phid,p) Gauss upwind; //div(phid,p) Gauss LUST default; div(phid,p) Gauss limitedLinear 1; div(phiv,p) Gauss limitedLinear 1; //div(phid,p) Gauss MUSCL; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; reconstruct(rho) vanLeer; reconstruct(U) vanLeerV; reconstruct(T) vanLeer; } snGradSchemes { default corrected; } wallDist { method meshWave; } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2112 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(rho|rhoU|rhoE)" { solver diagonal; } "(rho|U|h|k|e|omega)" { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0.01; } } relaxationFactors { fields { p 0.3; rho 0.1; } equations { U 0.5; h 0.5; "(e|k|omega)" 0.5; } } // ************************************************************************* // Thank you very much for your valuable time |
September 12, 2023, 02:18 |
Furkan
I have also obtained the same set of errors using reactingFOAM for a combustion simulation. Try reducing the time-steps and the maximum Courant number in your solution, that was the problem in my case.
Regards. |
September 13, 2023, 05:12 |
#3 | |
Sakun
Rep Power: 6 |
Hello, Thank you very much for the reply, I did actually tried those options but not succeeded |
compressible flow, compressor blade, periodic condition, unsteady |
Correct way of defning thermophysicalProperties for rhoCentralFoam | vachan | OpenFOAM Programming & Development | 1 | May 13, 2022 13:55 |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Reporting a bug in Allrun script on wingMotion case | i.sabahi | OpenFOAM Bugs | 0 | June 10, 2018 09:00 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
