Runing InterFoam for 3 D damBreak case Patch issue
Old   December 13, 2007, 08:32
Default Hi .. i am trying to run da
Nishant
nishant_hull is on a distinguished road
Hi ..
i am trying to run damBreak case for 3 D case and My blockmesh looks ok with the geometry but there are some issue with the patch. I m getting some warning related to patch. I have taken the boundary conditions of side walls (which was empty-type in 2 D case and run well on my machine) similar to the rightwall boundary condition.i.e. Zerogradient/u=0.
The error reported as:
[343880@w191-210 interFoam]$ interFoam . damBreak-expt
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : interFoam . damBreak-expt
Date : Dec 13 2007
Time : 13:25:31
Host : w191-210
PID : 6147
Root : /home/343880/OpenFOAM/343880-1.4.1/run/tutorials/interFoam
Case : damBreak-expt
Nprocs : 1
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: -0
Starting time loop
deltaT = 0.000595238
Time = 0.000595238
MULES: Solving for gamma
Liquid phase volume fraction = 0.232558 Min(gamma) = 0 Max(gamma) = 1
#0 Foam::error::printStack(Foam:stream&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0x110420]
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::multiply<foam::fvspatchfield,>(Foam::Geometr icField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator*<foam::fvspatchfield,>(Foam::tmp<fo am::geometricfield<double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&) in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#6 main in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/home/343880/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/interFoam"
Floating point exception
Also the WARNINGS with blockmesh utility is like :
--> FOAM Warning :
From function cellModel::mag(const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.C at line 134
zero or negative pyramid volume: -0.013065 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -0.013065 for face 5
--> FOAM Warning :
From function blockMesh::createTopology(IOdictionary& meshDescription)
in file createTopology.C at line 391
negative volume block : 22, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -0.015075 for face 5
--> FOAM Warning :
negative volume block : 34, probably defined inside-out
Default patch type set to empty
Check block mesh topology
Basic statistics
Number of internal faces : 70
Number of boundary faces : 70
Number of defined boundary faces : 70
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating points
Creating cells
Creating patches
Creating mesh from block mesh
Creating merge patch pairs
Writing polyMesh
end
BlockMeshDict file is attached.
blockMeshDict
Can anyone please look into it and let me know of the problem. Looking forward for your suggestions in this regard..
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   December 13, 2007, 11:19
Default CHECKMESH provide the followin
Nishant
CHECKMESH provide the following results:-
[343880@w191-210 interFoam]$ checkMesh . damBreak-expt
Exec : checkMesh . damBreak-expt
Date : Dec 13 2007
Time : 16:10:42
Host : w191-210
PID : 6566
Nprocs : 1
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
edges: 99820
faces: 96300
internal faces: 89460
cells: 30960
boundary patches: 4
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 30960
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Topological cell zip-up check OK.
Face vertices OK.
Face-face connectivity OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface
leftWall 540 589 ok (not multiply connected)
rightWall 2628 2793 ok (not multiply connected)
lowerWall 1932 2021 ok (not multiply connected)
atmosphere 1740 1829 ok (not multiply connected)
Checking geometry...
Domain bounding box: (0 0 0) (0.805 0.25 0.25)
Boundary openness (-9.05278e-17 -1.4379e-15 1.01299e-15) OK.
***High aspect ratio cells found, Max aspect ratio: 1.31439e+196, number of cells 30960
<<Writing 30960 cells with high aspect ratio to set highAspectRatioCells
Minumum face area = 4.44444e-05. Maximum face area = 0.000285938. Face area magnitudes OK.
Min volume = 2e-300. Max volume = 2e-300. Total volume = 6.192e-296. Cell volumes OK.
Mesh non-orthogonality Max: 180 average: 180
***Number of non-orthogonality errors: 89460.
<<Writing 89460 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 185760 faces are incorrectly oriented.
<<Writing 96300 faces with incorrect orientation to set wrongOrientedFaces
Max skewness = 6.66134e-14 OK.
Min/max edge length = 0.00666667 0.01875 OK.
All angles in faces OK.
Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1
All face flatness OK.
Failed 3 mesh checks.
End
Can anybody tell me, where am i going wrong??
Nishant
Thanks and regards,
Nishant
Old   December 13, 2007, 11:43
Default Yes - reported non-orthogonali
Hrvoje Jasak
Yes - reported non-orthogonality is 180 deg, and it should be (well) below 90 deg. This mesh is wrong - did you actually look at it?
Hrv
Hrvoje Jasak
Old   December 15, 2007, 12:17
Default Yea. There was kinda basic mis
Nishant
Yea. There was kinda basic mistake of not taking x-y-z system in proper order. now my case is running fine.
Thank you hrv!
cheers!!
Thanks and regards,
Nishant
Old   February 18, 2009, 00:25
Default Hi Nishant, I am also getting
Sayantan Datta Gupta
rishi123 is on a distinguished road
Hi Nishant,
I am also getting the same error as you reported in cavity problem with icoFoam. Your previous post tells about "xyzsystem" can you explain the solution.
Bye
Rishi
P.S: I am attaching my blockmeshdict file content
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.1;
vertices
(0 0 0)
(0.5 0 0)
(1 0 0)
(0 -0.5 0)
(0.5 -0.5 0)
(1 -0.5 0)
(0.5 -1 0)
(1 -1 0)
(0 0 0.1)
(0.5 0 0.1)
(1 0 0.1)
(0 -0.5 0.1)
(0.5 -0.5 0.1)
(1 -0.5 0.1)
(0.5 -1 0.1)
(1 -1 0.1)
blocks
hex (0 1 4 3 8 9 12 11) (10 5 1) simpleGrading (1 1 1)
hex (1 2 5 4 9 10 13 12) (10 5 1) simpleGrading (1 1 1)
hex (4 5 7 6 12 13 15 14) (10 5 1) simpleGrading (1 1 1)
edges
patches
wall movingWall
(0 8 9 1)
(1 9 10 2)
wall fixedWalls
(0 3 11 8)
(3 4 12 11)
(2 10 13 5)
(4 12 14 6)
(6 7 15 14)
(5 13 15 7)
empty frontAndBack
(0 1 4 3)
(1 2 5 4)
(4 5 7 6)
(8 9 12 11)
(9 10 13 12)
(12 13 15 14)
mergePatchPairs
Rishi
rishi123 is offline   Reply With Quote
Old   February 18, 2009, 00:32
Hi Nishant,
Bye
Rishi
FoamFile
version 2.0;
format ascii;
class dictionary;
vertices
(0 0 0)
(0.5 0 0)
(1 0 0)
(0 -0.5 0)
(0.5 -0.5 0)
(1 -0.5 0)
(0.5 -1 0)
(1 -1 0)
(0 0 0.1)
(0.5 0 0.1)
(1 0 0.1)
(0 -0.5 0.1)
(0.5 -0.5 0.1)
(1 -0.5 0.1)
(0.5 -1 0.1)
(1 -1 0.1)
blocks
edges
patches
wall movingWall
(0 8 9 1)
(1 9 10 2)
wall fixedWalls
(0 3 11 8)
(3 4 12 11)
(2 10 13 5)
(4 12 14 6)
(6 7 15 14)
(5 13 15 7)
empty frontAndBack
(0 1 4 3)
(1 2 5 4)
(4 5 7 6)
(8 9 12 11)
(9 10 13 12)
(12 13 15 14)
mergePatchPairs
Rishi
Interfoam Droplet under shear test case adona058 OpenFOAM Running, Solving & CFD 3 May 3, 2010 18:46
Help on interFoam writeControl in damBreak tutorial asaha OpenFOAM Running, Solving & CFD 1 February 2, 2009 07:36
[OpenFOAM] ParaFOAM issue with cavity case mschoenberg ParaView 3 November 21, 2008 03:57
Cylindrical Patch for interFoam vatant OpenFOAM Running, Solving & CFD 3 December 12, 2006 04:08
Problems starting new case interFoam billy OpenFOAM Running, Solving & CFD 3 June 21, 2006 10:18
