foam-extend-4.0 pimpleDyMFoam stops suddenly when running in parallel |
April 18, 2017, 08:04 |
Rep Power: 9 |
Dear Foamers,
I am facing a problem concerning a parallel computation in foam-extend-4.0 on openSUSE 42.1 Leap. I want to investigate VIV of a circular cylinder using the pimpleDyMFoam solver. The calculation works fine using 1 processor. When I try do to a parallel computation using Code:
mpirun -np 4 pimpleDyMFoam -parallel I already did a parallel computation with pisoFoam and this worked perfectly. This are the last lines of the log.mpirun-file (whole log-file in attachment): Code:
Starting time loop Courant Number mean: 0.0159612 max: 0.361299 velocity magnitude: 1 --> FOAM Warning : From function dlLibraryTable::open(const dictionary& dict, const word& libsEntry, const TablePtr tablePtr) in file lnInclude/dlLibraryTableTemplates.C at line 67 library "libsampling.so" did not introduce any new entries Searching for probe point locations Time = 0.00025 Restraint verticalSpring spring length 0.2 force (-0 0 -0) moment (0 0 0) Constraint fixedLine1 error (8.00292e-10 0 0) force (-0.00896327 -0 -0) moment (0 0 0) converged sixDoFRigidBodyMotion constraints converged in 1 iterations Constraint force: (-0.00896327 0 0) Constraint moment: (0 0 0) Centre of mass: (3 0 0.05) Linear velocity: (4.80175e-07 -1.18923e-21 4.27439e-39) Angular velocity: (8.76288e-23 -8.35888e-22 8.40257e-20) GAMG: Solving for cellDisplacementx, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for cellDisplacementy, Initial residual = 0, Final residual = 0, No Iterations 0 volume continuity errors : volume = 2.99921, max error = 0, sum local = 6.49626e-314, global = 0 PIMPLE: iteration 1 BiCGStab: Solving for Ux, Initial residual = 1, Final residual = 9.84448e-09, No Iterations 3 BiCGStab: Solving for Uy, Initial residual = 1, Final residual = 1.37882e-07, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.00681398, No Iterations 24 Moving mesh time step continuity errors : sum local = 1.16265e-08, global = -4.98565e-10, cumulative = -4.98565e-10 PIMPLE: iteration 2 BiCGStab: Solving for Ux, Initial residual = 0.0346077, Final residual = 3.4695e-07, No Iterations 2 BiCGStab: Solving for Uy, Initial residual = 0.332333, Final residual = 8.04175e-08, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0660635, Final residual = 8.14216e-08, No Iterations 57 Moving mesh time step continuity errors : sum local = 1.70333e-12, global = -2.45975e-14, cumulative = -4.9859e-10 ExecutionTime = 1.11 s ClockTime = 1 s Courant Number mean: 0.0164681 max: 0.529879 velocity magnitude: 1.46659 Time = 0.0005 Restraint verticalSpring spring length 0.2 force (-0 0 -0) moment (0 0 0) Constraint fixedLine1 error (9.35335e-08 0 0) force (-1.04758 -0 -0) moment (0 0 0) not converged Constraint fixedLine1 error (2.806e-08 0 0) force (-0.314273 -0 -0) moment (0 0 0) not converged Constraint fixedLine1 error (8.41801e-09 0 0) force (-0.0942818 -0 -0) moment (0 0 0) not converged Constraint fixedLine1 error (2.5254e-09 0 0) force (-0.0282845 -0 -0) moment (0 0 0) not converged Constraint fixedLine1 error (7.57621e-10 0 0) force (-0.00848536 -0 -0) moment (0 0 0) converged sixDoFRigidBodyMotion constraints converged in 5 iterations Constraint force: (-1.4929 0 0) Constraint moment: (0 0 0) Centre of mass: (3 -5.94617e-25 0.05) Linear velocity: (4.54573e-07 -1.05822e-09 1.29309e-20) Angular velocity: (8.43161e-20 -1.30344e-19 -9.97196e-12) GAMG: Solving for cellDisplacementx, Initial residual = 1, Final residual = 7.82687e-06, No Iterations 30 GAMG: Solving for cellDisplacementy, Initial residual = 0.00334489, Final residual = 9.43799e-06, No Iterations 9 I attached also the whole case I am using. If want to run the case in parallel just execute Code:
./Allrun_par For 1 processor execute Code:
./Allrun Kind regards, icab Last edited by icab; April 19, 2017 at 04:39. |
May 17, 2017, 13:21 |
MPirun failing for mesh motion
chinmoy
I am facing similar problem for interDyMFoam with Foam-Extend 4.0.
Display Modes | |
Error while running pimpleDyMFoam (parallel) | DOliveira | OpenFOAM Running, Solving & CFD | 0 | July 17, 2015 05:41 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 05:14 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 08:53 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
