How to run the tutorials' problems?
Old   July 24, 2014, 03:43
Default How to run the tutorials' problems?
rana
ranasa is on a distinguished road
Hello guys,
i'm a beginner in Openfoam
in order to learn more, i wanna to run some of the problems in the tutorials folder. but there is a problem that i got confused how to run different cases.
How should i know about the orders to be typed in terminal for running the different problems?
best
ranasa is offline   Reply With Quote
Old   July 24, 2014, 13:12
Jefferson Vieira
Jefferson_dhv is on a distinguished road
Some tutorials have the Allrun file in the case directory. In these cases you can simply type "./Allrun" when you are at the case directory in the terminal. You can access the case directory in the terminal by typing "cd" followed by the path, for example "cd /home/user/run/tutorials/incompressible/simpleFoam/airFoil2D/". In the other cases you need to do manually, some need to build the mesh and other just need to be ran by typing the name of the solver when within the case directory, just typing "simpleFoam", for example.
To learn how OpenFOAM works I recommend first to read the User Guide and then try to run the tutorials manually.
Regards,
J. Vieira
Jefferson_dhv is offline   Reply With Quote
Old   July 24, 2014, 15:10
rana
Dear Jefferson,
thanks for your valuable comments. i've just learned about the user Guide and i'm gonna make a deep study on it.
Best,
Rana
OpenFOAM-2.1 instability problems? aliqasemi OpenFOAM Bugs 9 February 15, 2017 06:39
Case running in serial, but Parallel run gives error atmcfd OpenFOAM Running, Solving & CFD 18 March 26, 2016 12:40
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 19:39
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
PotentialFoam few problems chris_sev OpenFOAM Running, Solving & CFD 1 July 22, 2008 10:15
