ChtMultiRegionFoam kOmegaSST solidDisplacementFoam
Old   January 15, 2009, 02:12
Default Hi all, I'm new to OpenFOAM
Marco Müller
marico is on a distinguished road
Hi all,
I'm new to OpenFOAM (just did tutorials) and want to ask you if it is possible to perform the following task (I did before in CFX) THEORETICALLY:
1. Solve a (geometrically complex) Problem with chtMultiRegionFoam (one Fluid, one Solid) with kOmegaSST model (as a ANSYS user it was me presented a the "ultimate" model for calculating heat fluxes in practical engineering problems) in STEADY STATE:
1a) Has the solver to be customized for that (as it is designed for transient...) or can it be modified in solver settings without recompiling?
1b) Has anyone experience with that?
1c) Whats the "Near wall treatment" in OpenFOAM generally, but especially for that turbulence model? In CFX it has an "automatic" treatment, which allows the use of fine AND rough (of course, not so nice) grids. Do I HAVE TO create yplus ~1 grids for this model?
2. Solve a STEADY STATE simulation after that with solidDisplacementFoam:
2a) solidDisplacementFoam is designed for transient but solidEquilibriumDisplacementFoam doesnt seem to include thermal stresses?! Which solver is appropriate if I want to calculate the displacements and stresses with the former calculated temperature field? Any experience?
2b) The procedure I estimate for that would be:
- Take the T field from first solution
- Set the field as constraint for displacements (How do I define that? For its not only boundaries but also the inner field that has to be set...)
Thanks a lot for your answers (and for that software)!!
Marco
marico is offline   Reply With Quote
Old   January 15, 2009, 04:51
Default Hi Marco, I can only reply
Kati Laakkonen
kati is on a distinguished road
Hi Marco,
I can only reply following (note that I haven't tested the chtMultiRegionFoam):
1a) You might try ddtScheme CoEuler or SLTS. They locally limit the time step. See comments in their source code (you'll find ddtSchemes in OpenFOAM-1.5/src/finiteVolume/finiteVolume/). Or if your other schemes are diffusive enough (upwind etc) you will finally get a steady solution anyway.
1c) kOmegaSST in OpenFOAM is hardcoded with wall functions. So keep your y+ in logarithmic region. Most widely used models in OF are coded with wall functions, but there are some low-Re models, and SpalartAllmaras and LES models can be used as hybrid.
2a) If there is no temperature field in the solver, I think you'll have to design your own solver.
Regards,
Kati
kati is offline   Reply With Quote
Old   January 16, 2009, 01:45
Default Hi Katy, thanks a lot for y
Marco Müller
Hi Katy,
thanks a lot for your reply. In easy language, what does "keep y+ in logarithmic region" mean?
Value for y+ lower than 11?
What happens if it is too small or too big?
Marco
Old   January 16, 2009, 01:49
Marco Müller
Hi Katy,
Marco
Old   January 16, 2009, 02:51
Default You should check a book on bou
Kati Laakkonen
You should check a book on boundary layer theory to find out what is logarithmic region. Something like y+~30-400. If y+ is too small or too big, the assumptions of the model are not valid which then decreases the quality of the results. This is not OpenFOAM specific. Good luck.
Kati
Compressible kOmegaSST cosimobianchini OpenFOAM Bugs 78 June 4, 2017 14:00
SolidDisplacementFoam philippose OpenFOAM Running, Solving & CFD 11 May 27, 2014 05:27
ChtMultiRegionFoam and P1 radiation model mabinty OpenFOAM Running, Solving & CFD 18 April 8, 2011 04:41
ChtMultiRegionFoam haewon OpenFOAM Running, Solving & CFD 6 August 27, 2009 10:02
Please help develop new BC for chtMultiRegionFoam hsieh OpenFOAM Running, Solving & CFD 0 January 21, 2009 09:48
