This is the fix.
http://ww
The algorithm posted by Jarrod
The algorithm posted by Jarrod a few threads above (for evaluating flux at the patches such as inlet etc) works fine. But what if I have a channel of say length L=1 (from x=0 to x=1) and I want to calculate flux through the middle point (x=0.5). How do I introduce a face at x=0.5 which is not a boundary patch? I found the velocities at the middle to be more accurate, so I thought calculating flux at the middle would be better. inlet flux changes its sign while it shouldn't be like that. I guess something may be wrong there.
Dear all,
Keeping the idea
Dear all,
Keeping the idea of Ali, I need to calculate a mass flow average throught a plane in my geometry. I'll like also to define this plane (coordinate, ect...) after my calculation because I can't guess the result. I use these few lines to create a plane inside the geometry where I can get every value I need. // Plane 1 point pnt(0,0,0); vector direction(0,0,1); plane pl1(pnt,direction); cuttingPlane cutPlane1(mesh,pl1); const labelList& cutCells1 = cutPlane1.cells(); word setName("someCells"); cellSet currentSet1(mesh, setName, cutCells1); // Create mesh subsetting engine fvMeshSubset subsetter1(mesh); label patchI = -1; subsetter1.setLargeCellSubset(currentSet1, patchI, true); But, how can I use them to define a patch like boundary patch which wouldn't be at the boundary of my geometry ? So I could use previous piece of code to get different value like mass flow average or pressure average, ect ... Thank you for your help, Cedric |
dear all!!
added the posted codes to chtMultiRegionFoam to get the net mass flux in the fluid region(s). it compiles but giving me the following warnings: ************************************************** ******************************* fluid/setRegionFluidFields.H: In function ‘int main(int, char**)’: fluid/setRegionFluidFields.H:1: warning: unused variable ‘mesh’ fluid/setRegionFluidFields.H:5: warning: unused variable ‘K’ fluid/setRegionFluidFields.H:6: warning: unused variable ‘U’ fluid/setRegionFluidFields.H:7: warning: unused variable ‘phi’ fluid/setRegionFluidFields.H:8: warning: unused variable ‘g’ fluid/setRegionFluidFields.H:10: warning: unused variable ‘turb’ fluid/setRegionFluidFields.H:11: warning: unused variable ‘DpDt’ fluid/setRegionFluidFields.H:14: warning: unused variable ‘psi’ fluid/setRegionFluidFields.H:15: warning: unused variable ‘h ************************************************** ******************************* but the code is running. should I stil care about the warnings?? greatly appreciate your comments! aram |
Is this mass flux or mass flow rate ?
I have a question about the code you have posted here. Does it calculate Mass Flux or Mass flow rate ? Thanks Vaidya Quote:
hi
I have a question about about where should we add the includes and their related headers? |
immortality: Have you heard about the phrase thread necromancy before?
I really think it is bad practice to post the same question twice on the same forum at the same time. Post it once, and wait for answer. |
i didn't received a related answer yet.
