Problem with icoDyMFoam
Old   March 17, 2008, 02:58
Default Hello everybody I have been
olivier Petit
olivier is on a distinguished road
Hello everybody
I have been starting to use OpenFoam not so long ago, and right now I am focusing on understanding the sliding interface code. In order to do that, I have been studying the code and the different tutorials one can find on svn and on the forum. To see if I had understood it correctly, I have done my own case, which is quite simple: my case conists in a conical diffuser, you can find the set up on the following link;
http://openfoamwiki.net/index.php/Si...e_next_meeting
I used the working case mixer2D to set up my case but unfortunately, something does not make sense:
in the dynamicMeshDict, you have to specify which part of your sliding interfice is rotating and which is not:
dynamicFvMeshLibs 1("libtopoChangerFvMesh.so");
dynamicFvMesh mixerFvMesh;
mixerFvMeshCoeffs
coordinateSystem
type cylindrical;
origin (0 0 0);
axis (0 0 1);
direction (1 0 0);
rpm 10;
slider
inside insideSlider;
outside outsideSlider;
In my case, only the wrong part of the geometry is rotating, no matter which part of the slider i put as inside or outside.
Does anyone has some clues on what is happening?
Thank you very much
olivier is offline   Reply With Quote
Old   March 17, 2008, 03:17
Default The rotating part is chosen to
Hrvoje Jasak
The rotating part is chosen to be closest contiguous domain to the origin of the coordinate system. I know this is not absolutely general but it seemed like a good idea at the time.
Do you need this changed/how would you like to define the rotating part?
Hrv
Hrvoje Jasak
Old   March 17, 2008, 03:29
Default I thought that the rotating pa
olivier Petit
I thought that the rotating part was defined in the dynamicMeshDict, with the definition of inside and outside. The origin of my coordinate system is at the entrance of the diffusor, so that makes sense and I do understand now my mistake. Is there some way to define the rotating part in an other way, let's say by using dynamicMeshDict? In the DynamicMeshDict, we can define an origin :
type cylindrical;
origin (0 0 0);
axis (0 0 1);
direction (1 0 0);
Is it possible to use this part to define the rotating part?
olivier
Old   March 17, 2008, 03:54
Default Well, look at what the code is
Hrvoje Jasak
Well, look at what the code is doing:
// Mark every cell with its topological region
regionSplit rs(*this);
// Get the region of the cell containing the origin.
label originRegion = rs[findNearestCell(cs().origin())];
labelList movingCells(nCells());
label nMovingCells = 0;
forAll(rs, cellI)
if (rs[cellI] == originRegion)
movingCells[nMovingCells] = cellI;
nMovingCells++;
movingCells.setSize(nMovingCells);
Info << "Number of cells in the moving region: " << nMovingCells << endl;
Read:
- find nearest cell to the origin
- grab all cells in a detached zone around the origin
I am quite happy to add all other ways to do this, but some input is required: How would you like to collect the moving cells?
Hrv
Hrvoje Jasak
Old   March 17, 2008, 04:39
Default Hi Hrvoje thank you for you
olivier Petit
Hi Hrvoje
thank you for your quick answers. Now that I know where the problem lies, I have just translated my geometry so that the origin lies is located in the desire part.
But I was thinking of an other way to get the region of the cells that are supposed to move: do you think it is doable to get the moving cells by specifying some kind of boundary region? I mean like specifying that the movingCells are to be find between inlet, movingWall and insideSlider. Do you think it would be doable?
olivier
Old   March 17, 2008, 05:08
Default Well, all I need is a cell zon
Hrvoje Jasak
Well, all I need is a cell zone containing moving cells. The problem is that the cell zone has to be detached from the rest of the mesh by boundaries and detached from the rest of the mesh - this is why I prefer to have it calculated automatically.
The question boils down to: are the users sophisticated enough to grasp this? If you think so, we can easily add an optional argument of moving cell zone name.
Hrv
Hrvoje Jasak
Old   March 17, 2008, 05:25
Default I am thinking of finding the b
olivier Petit
I am thinking of finding the best way to specify the rotating region, but first I need to understand all entries in the dynamicMeshDict. It seems like origin and axis define the rotational axis. This origin has nothing to do with the one used in the code to define the moving cells. Is this correct?
There is also the direction which i do not understand the purpose of. Can you explain it to me please?
I would propose to specify in this dynamicMeshDict an other point that would be used in the definition of the moving cells, instead of the origin. That would be very easy to implement. The default value could still be the origin.
Thank you
olivier
Old   March 17, 2008, 11:14
Default Hi Hrv, From the piece of c
Håkan Nilsson
hani is on a distinguished road
Hi Hrv,
From the piece of code you presented I guess that it would be sufficient to modify the following line so that the user can specify the point instead of using the origin:
That would be general enough, and it wouldn't require too much from the user. The point could be specified in the dynamicMeshDict, and it may be called something like rotatingRegionMarkerPoint
Håkan.
hani is offline   Reply With Quote
Old   March 17, 2008, 18:12
Default Agreed - do you fancy doing it
Hrvoje Jasak
Agreed - do you fancy doing it?
Hrv
Hrvoje Jasak
Old   October 29, 2008, 04:52
Default Hi, I have been trying to set
Pal Schmitt
waterboy is on a distinguished road
I have been trying to set up a mixer-like case with 1.4.1-dev. Hroves 3D mixer case is running fine but mine quits with a segmentation fault.
Exec : icoDyMFoam . mixer3DPal
Date : Oct 29 2008
Time : 10:13:54
Host : pc080442
PID : 4591
Root : /home/negast1/OpenFOAM/negast1-1.4.1-dev
Case : mixer3DPal
Nprocs : 1
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh mixerFvMesh
void mixerFvMesh::addZonesAndModifiers() : Zones and modifiers already present. Skipping.
Mixer mesh
origin: (0 0 150)
axis : (0 0 1)
rpm : 10
Reading transportProperties
Reading field p
Reading field U
Starting time loop
Volume: new = 3.91431e+08 old = 3.91431e+08 change = 0
Courant Number mean: 0 max: 0
deltaT = 1.1999e-05
Time = 1.1999e-05
Segmentation fault
I tried to understand the code but still have doubts. Is it OK that it says
I understand I need to define zones. But The zone movingcells is created by foam, according to the above, right? By the way, is it smart to create zones from Sets with setsToZones if importing a *.unv mesh or are there better ways?
Thanks a lot for any help, I can share my case, if anyone bothers to see it. The origin defined in dynamicMeshDict is inside the moving part region...
Cheers,
Pal
waterboy is offline   Reply With Quote
Old   October 29, 2008, 08:57
Default Ok, stupid question:-) You rea
  #11
Pal Schmitt
Ok, stupid question:-) You really only need the two patches and origin. As easy as that...
Old   November 11, 2008, 11:35
Default Hello everyone, it was quit
  #12
Naoko Oyama
naoko_oyama is on a distinguished road
Hello everyone,
it was quite clear for me how the code defines the rotating part by Prof. Jasak's explanation.
I'm working with 1.4.1-dev with GGI between the rotating part and the static part. It works pretty fine when I want to rotate a single region.
My question is; Has anyone worked with multiple rotating regions?
I had a look in the code of mixerGgiFvMesh.C and it seems that I need to make a change there to do so, however I am still struggling with the code.. If anyone had experienced this or has any idea how to do this, I would love to know...
Thank you
Naoko
naoko_oyama is offline   Reply With Quote
Old   November 17, 2008, 05:22
Default Hello Foamers, I am trying
  #13
Mahendra
mahendra is on a distinguished road
Hello Foamers,
I am trying to run the mixerVessel2D case using icoDyMFoam, but I am getting the following error.
Please help me in resolving the error.
ms.wankhede@linux:~/OpenFOAM/ms.wankhede-1.5/tut/icoDyMFoam/mixerVessel2D> icoDyMFoam
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.5 |
| \ / A nd | Web: http://www.OpenFOAM.org |
| \/ M anipulation | |
Exec : icoDyMFoam
Date : Nov 17 2008
Time : 15:55:44
Host : linux
PID : 24762
Case : /home/ms.wankhede/OpenFOAM/ms.wankhede-1.5/tut/icoDyMFoam/mixerVessel2D
nProcs : 1
Create time
Create mesh for time = 0
Unknown dynamicFvMesh type mixerFvMesh
Valid dynamicFvMesh types are :
5
dynamicRefineFvMesh
staticFvMesh
dynamicMotionSolverFvMesh
dynamicInkJetFvMesh
solidBodyMotionFvMesh
From function dynamicFvMesh::New(const IOobject&)
in file dynamicFvMesh/newDynamicFvMesh.C at line 79.
FOAM exiting
Where can i find mixerFvMesh, or do i need to make it?
Regards,
Mahendra.
mahendra is offline   Reply With Quote
Old   December 19, 2008, 09:03
Default Hello Mahendra, actually i
  #14
tino boelke
tino_boelke is on a distinguished road
Hello Mahendra,
actually i have the same problem, look at this
http://www.cfd-online.com/OpenFOAM_D...tml?1229605359
did you find a solution? Im sure well solve this problem with help of this Forum.
Regards, Tino.
tino_boelke is offline   Reply With Quote
Mesh Problem with icoDyMFoam yuhai OpenFOAM Running, Solving & CFD 5 January 14, 2009 14:57
Mesh Problem with icoDyMFoam yuhai OpenFOAM Running, Solving & CFD 0 January 12, 2009 17:53
Problem with icoDyMFoam tutorial matlie OpenFOAM Bugs 10 April 26, 2007 04:51
Problem starting with icoDyMFoam kassiotis OpenFOAM Running, Solving & CFD 1 March 12, 2007 11:12
Problem with icoDyMFoam philippose OpenFOAM Running, Solving & CFD 19 March 7, 2007 12:06
