June 11, 2010, 05:53 |
simpleFoam ddt Euler ?
Moritz Wied
Rep Power: 16 |
Hi Foamers,
i made some funny experiences with simpleFoam. As is switched from piso to simple i forgot to change the ddtScheme from Euler to steadyState in the fvSchemes. now if i changed the timestep to a very low value (1e-11), i was able to run simpleFoam with a quick convergence and a result that looks very good. my setup: - air flow arround ahmed body - LamBremhorstKE lowRe - velocity 40 m/s - polymesh made with ccm+ with 10 surface layers - k eps bounded if i use pisoFoam or simpleFoam with ddtScheme steadyState, i have to start with a low velocity and carefully rise it step by step not to diverge with k and epsilon. with ddtScheme Euler and the timestep 1e-11 (nothing else changed), it converges with bc 40 m/s and initial field 0 m/s without rising step by step. Does anybody know, if simpleFoam can "officialy" be used for transient calculations or how the ddt term is taken into account? Maybe this might also help somebody to get a initial field... bye, mo |
June 11, 2010, 06:46 |
Stefan Herbert
Rep Power: 17 |
Hi Moritz,
all the equations in simpleFoam do not include any ddt-terms. Therefore time scheme is not used at all. But inside the turbulence model it is used. I don't think that your results could be this good, because solving k- and epsilon-equations with such a small time-step (1e-11!) would be like underrelaxation of near zero! Then you won't have any trouble concerning convergence, of course, but on the other hand your results won't change, do they? In general simpleFoam cannot be used for transient calculations. Regards, Stefan |
June 12, 2010, 13:36 |
#3 | |
Alberto Passalacqua
Rep Power: 36 |
Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
Laminar simpleFoam and inviscid simpleFoam | herenger | OpenFOAM Running, Solving & CFD | 7 | July 11, 2013 06:27 |
Naca0012 k-e mpirun gives fpe whereas simpleFoam not | Pierpaolo | OpenFOAM | 1 | May 8, 2010 03:08 |
Blood Flow - Euler Euler | Ilias | FLUENT | 0 | January 12, 2009 10:16 |
euler model | CN | FLUENT | 0 | July 4, 2005 16:35 |
Euler equations? | Jan Ramboer | Main CFD Forum | 2 | August 19, 1999 01:58 |
