November 30, 2008, 06:52 |
createMpSource.H:17: error: no
Henrik Rusche
Rep Power: 18 |
createMpSource.H:17: error: no matching function for call to 'Foam::fvMesh::findCell(Foam::dimensionedVector&)'
/home/sea/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/primitiveMesh.H:662: note: candidates are: Foam::label Foam::primitiveMesh::findCell(const Foam::point&) const The compiler trys to tell you that your variable sp of type dimensionedVector cannot automatically converted into a point. Try sp.value(). (Vectors can be converted into points) Henrik |
December 1, 2008, 05:14 |
Dear Henrik,
Thank you very
Seiji Adachi
Rep Power: 17 |
Dear Henrik,
Thank you very much for your reply. Now I understand the difference between point(=vector) and dimensionedVector. The latter has a name and dimensions in addition to its value. This is why value() is needed to extract the value here. I made the same mistake at line 19. The code was rewrote as follows and it worked! ------------------------------------------------ // Add value of 1/v to deltaFunc at the point of sp!!! label celli(mesh.findCell(sp.value())); dimensionedScalar vol = mesh.V()[celli]; deltaFunc[celli] = 1.0/vol.value(); ------------------------------------------------ Cheers, Seiji |
Scalar Dissipation - delta function assumption | Tristan Collins | FLUENT | 0 | December 13, 2007 07:15 |
How to calculte \Delta t from CFL? | Annie | Main CFD Forum | 4 | March 23, 2005 09:48 |
LES delta | turb | Main CFD Forum | 2 | March 2, 2005 14:27 |
Making the density a function additional variab. | Sebastien Perron | CFX | 4 | August 8, 2003 08:03 |
Delta wing | Thomas Pettersson | FLUENT | 1 | April 22, 2000 20:18 |
