dieselEngineFoam OpenFOAM-1.6 SigFPE error
Old   September 24, 2009, 04:32
Default dieselEngineFoam OpenFOAM-1.6 SigFPE error
Arun
arun is on a distinguished road
Hi All,
I am simulation the combustion of diesel fuel using kiva mesh in OpenFOAM-1.6 using dieselEngineFoam. The fuel is injected at -30 cad (pilot) and -6 cad (main). Once the simulation reach 3.4 cad the simulation gives floating point exception error.
The error shown below:
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/keyzhi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/keyzhi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::solve(double, double) in "/home/keyzhi/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libchemistryModel.so"
#4 main in "/home/keyzhi/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/dieselEngineFoam"
#5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
I am not really sure what actually cousing this problem.
Thanks in advance.
Arun
arun is offline   Reply With Quote
combustion, diesel engine, dieselenginefoam, floating point error, spray
OpenFOAM Version 1.6 Released opencfd OpenFOAM Announcements from ESI-OpenCFD 0 July 27, 2009 17:55
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Building error of 15dev for OpenSUSE 111 on AMD64 machine waynezw0618 OpenFOAM Installation 1 February 18, 2009 10:12
Installation problem with GCC Norma McKee (Mckee) OpenFOAM Installation 10 March 4, 2007 07:09
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
