Simulating inlet consisting of many small holes |
October 14, 2008, 10:53 |
I wonder if someone could help
Christian Lindbäck
Rep Power: 17 |
I wonder if someone could help me with the following. Air is pumped into a room through a plate with a lot of small holes. If I don't account for this, the velocity will be wrong given a specific volume flow which I know.
On the other hand, accounting for these tiny holes through meshing is out of the question. So what can I do? The area of the inlet will be too big if I disregard the fact that the inlet really is a perforated plate. But what if I increase the fluid density on the inlet. Then the momentum (rho*U) will be correct as well as the volume flow (U*A). I mean, inside the domain, density is evaluated from other properties (I'm using bouyantSimpleFoam and buoyantFoam), not solved as a transport equation. This should work, right or wrong? But there will be a momentum over the entire inlet, in reality this momentum only occurs through the holes of the perforated plate. Consequences? Hope to hear your comments. Best regards, Christian Lindbäck |
October 15, 2008, 01:35 |
Hi Christian,
why don't you
Uwe Janoske
Rep Power: 17 |
Hi Christian,
why don't you model the perforated plate as a porous zone? If you have different volume flows the pressure drop over the plate will change automatically. Uwe |
October 15, 2008, 02:11 |
Hi Uwe,
What I want is to s
Christian Lindbäck
Rep Power: 17 |
Hi Uwe,
What I want is to set a volume flow V on an inlet with area A. However, due to the fact that the inlet is a perforated plate, I would want the velocity not to be U = V/A but V/(f*A) where f is an area factor between 0 and 1. Another option would be to increase the density at the inlet boundary so that the momentum is correct. How can I do this with a porous zone? |
October 15, 2008, 02:56 |
Hi Christian,
why don't you
Uwe Janoske
Rep Power: 17 |
Hi Christian,
why don't you extend the computational domain and set the inlet at a certain distance of the porous plate? Uwe |
Display Modes | |
How to model many small holes in a large domain? | Bryan Woods | FLUENT | 3 | February 5, 2009 19:34 |
Urgent: 3D hollow pipe with small holes at faces | ASHOK | CFX | 4 | February 3, 2009 16:25 |
About simulating laminar flow through small orific | ncj | Main CFD Forum | 1 | August 14, 2002 04:46 |
small size holes simulation | brian ko | Phoenics | 5 | October 22, 2001 12:53 |
