May 3, 2007, 10:27 |
Hi all,
I am trying to unders
rafal zietara
Rep Power: 17 |
Hi all,
I am trying to understand mixerVessel2D and i stuck (i need somebodys help). Here is what i figured out so far. I have found small script makeMesh. lets do it by parts: 1) generating blockMeshDict file by macros (inexpensive clever way of generating blockmesh on parameters) m4 <constant/polymesh/blockmeshdict.m4> constant/polyMesh/blockMeshDict 2) than standard mesh generation on the basis of blockMeshDict generated in 1) blockMesh .. mixerVessel2D 3) generation of a set of cells belonging to zone rotor cellSet .. mixerVessel2D 4) take cells obtained in 3) generate faces of those cells cp system/faceSetDict_rotorFaces system/faceSetDict faceSet .. mixerVessel2D 5) take faces from 4) and delete boundary faces cp system/faceSetDict_noBoundaryFaces system/faceSetDict faceSet .. mixerVessel2D - is that right? what boundaries?All? why? 6) write faceZones for the mesh on the basis of 5) setsToZones .. mixerVessel2D -noFlipMap so at the end we generated list of faces belonging to rotor region that are not boundary faces of a region? but why do we need this? 7) next kind of mistery is a file constant/MRFZones. it contains: name of zone = rotor - thats ok patch = rotor (unfortunately patch of this case has the same name like region :/) - what patch(es) i should specify here? all that are under centrifugal and/or Coriolis force that would normally rotate? origin, axis, omega - the rest is ok except look 8) 8) MRFZones defines origin, axis, omega the same things are defined in dynamicMeshDict. but wait, why do i need dynamicMeshDict in MRF? in MRF i have static mesh and i dont need sliding interfaces. is that right? i deleted this file and MRFSimpleFoam runs without problem. Does the existance of this file mean that i can actually somehow run it like old mixer2D in OF13? in a transient way with sliding interface? I tried icoDyMFoam with some minor fixes and it does not recognize mixerFvMesh as a valid type of dynamicFvMesh. mixerFvMesh exist in topoChangerFvMesh. how it is used in OF14? is it used at all? I will be happy to read any post giving light on any of this points. cheers, rafal |
September 6, 2007, 09:23 |
Hi Rafa,
did you succeed u
Gabriel Barroso
Rep Power: 17 |
Hi Rafa,
did you succeed understanding MRFsimpleFoam? Bests Gabriel |
September 6, 2007, 12:44 |
Hi Gabriel,
I have understood
rafal zietara
Rep Power: 17 |
Hi Gabriel,
I have understood some parts of it, but I quit the idea and no longer use it. If you drop me an email with the parts you do understand and with the parts you have problem with maybe I will be able to help you. |
September 22, 2008, 08:23 |
Hi people http://www.cfd-onlin
Mahendra
Rep Power: 17 |
Hi people
Can anyone please send me details with regards to simulation of Moving Refrence Frame Problem using OpenFOAM. I am unable to decipher anything form the Tutorial Problem.... My Eamil: mahendra.wankhede@gmail.com Regards, Mahendra |
August 21, 2014, 10:41 |
The same help!
#5 | |
Esteban Vargas
Rep Power: 11 |
Have you received an answer about this question? I really need the same help, I'm stuck. I really appreciate your time. Thanks and best regards. |
