IAPWSIF97 water properties
Like Tree8Likes
Old   December 7, 2011, 04:18
Henrik Rusche
henrik is on a distinguished road
Hi JinBao,
Christan Lucas at the TU Braunschweig has done some work on real gas thermodynamics which might find helpful. It includes implementations of aungierRedlichKwong, pengRobinson, redlichKwong, soaveRedlichKwong EOS.
Please checkout the feature/fullyIntegratedRealGasThermo branch on extend.
... and, yes, your contribution is more than welcome.
Best Regards,
Henrik
henrik is offline   Reply With Quote
Old   December 14, 2011, 09:35
Jinbiao Xiong
JinBiao is on a distinguished road
Send a message via MSN to JinBiao
Hi Henrik, Thank you for the helpful information. Christan Lucas's approach is very interesting. I will try to apply it in my calculation. Christan Lucas provided the tutorial for CO2. I am not sure the library will work for water. I will share my experience here after I try it.
I am also trying to get a successful calculation with my own property library. Thanks again.
Regards,
Jinbiao
JinBiao is offline   Reply With Quote
Old   May 15, 2012, 16:22
Haomin Yuan
yhaomin2007 is on a distinguished road
Hi, JinBiao:
I am doing something with OpenFOAM using some real gas model.
I want to know where do you fine the "Christan Lucas provided the tutorial for CO2."
thank you
yhaomin2007 is offline   Reply With Quote
Old   May 16, 2012, 02:46
Christian Lucas
Chris Lucas is on a distinguished road
you can find my code in the OpenFOAM extend on sourceforge. See link:
http://openfoam-extend.git.sourcefor...-ext;a=summary
Have a look at feature/fullyIntegratedRealGasThermo.
Best Regards
Christian
Chris Lucas is offline   Reply With Quote
Old   May 16, 2012, 04:59
Jinbiao Xiong
Hi Haomin,
I hope you have already get what you need. Because I am playing with water, I had no further experience with Lucas's library. But the structure of Lucas's implementation looks very good. Much better than I can do.
Good luck and enjoy it.
Regards,
Jinbiao
Jinbiao
Old   May 16, 2012, 05:06
Christian Lucas
Hi Jinbiao,
I forgot to ask you, is your IAPWS-IF97 implementation working? Did you implement it yourself or are you using external libraries like freeSteam.
Best Regards,
Christian
Old   October 19, 2012, 16:22
Default Supercritical water properties in FLUENT
  #27
Abhijeet Shrawage
ashrawage is on a distinguished road
Hello guys..
I am working on simulations which involves water at 24MPa and temperatures ranging from 350-700 C.
Like JinBiao, I have been using IAPWS equations (RefProp) to get data sets for K Cp, Rho and Viscosity.
With these data sets, I generated a plot in excel and fitted curves to get R squared values very close to 1.
Now i have implemented these curves as piecewise polynomials in Fluent material properties. But as of now i am consistently getting divergence in temperature or pressure correction errors the moment i initiate the calculations.
Do you have any recommendations regarding this? Or can you think of any better way to model Super critical water in Fluent?
Thanks a lot...
Abhijeet J S
ashrawage is offline   Reply With Quote
Old   October 19, 2012, 23:50
Default turbulent flow
  #28
diego gomez
diego gomez is on a distinguished road
hello, I'm just learning openFoam. could you tell me how can I simulate a turbulent flow? I know the icoFoam solver is only for laminar flow.
Thanks a lot,
Diego
diego gomez is offline   Reply With Quote
Old   October 22, 2012, 03:33
Christian Lucas
for all who are interested in IAPWS Water properties in OpenFOAM, I included
IAPWS water properties in the openFOAM 1.6.ext version. I use freeSteam to calculate the properties.
http://openfoam-extend.git.sourceforge.net/git/gitweb.cgi?p=openfoam-extend/OpenFOAM-1.6-ext;a=summary
see branch: feature/fullyIntegratedRealGasThermo
Kind Regards,
Christian
Old   October 22, 2012, 21:28
Adam
Smed is on a distinguished road
Christian,
Would you mind explaining how to download and install your IAPWS implementation? Can it also be used in version 2.1.1 or only in 1.6?
Smed is offline   Reply With Quote
Old   October 23, 2012, 03:47
Christian Lucas
the code is developed for OpenFOAM 1.6-ext (extend), so I am not sure if the code works in OpenFOAM 2.1.
The code is provided as a git branch, download OpenFOAM 1.6-ext
(see http://www.extend-project.de/). Change branch and connect your new branch to branch feature/fullyIntegratedRealGasThermo of the external repository (if needed, google for checkout of remote branch)
You can find the main source file in “src/thermophsicalModels/externalMedia”. You need to compile the code yourself (wmake libso), the code is not includes in the Allwmake file in src/thermophsicalModels/
Have a look at the tutorial ReadME file. The tutorial can be found at tutorials/compressible/rhoPisoFoam/ras/IAPWS97_Pipe. The file should explain what you need to do (mainly install freeSteam and provide the dynamic library to openFOAM)
Regards,
Christian
Old   October 23, 2012, 22:29
Adam
Christian,
I am not very familiar with git, so I would appreciate your help. I have downloaded OpenFOAM-1.6 ext using
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/openfoam-extend
If I look for “src/thermophsicalModels/externalMedia” at this point,
the externalMedia directory doesn't seem to exist. I'm guessing this is because I need to do something with the branches. I have tried
git checkout -b origin/feature/realGasThermo
But after executing this command, I still don't see an externalMedia directory. Can you please explain what I need to do next? Thanks.
Old   October 24, 2012, 02:53
Christian Lucas
try
git checkout -b feature/fullyIntegratetedRealGasThermo origin/feature/fullyIntegradetedRealGasThermo
maybe you need to use
git pull
afterwards
Regards,
Christian
Old   October 27, 2012, 11:40
Markus Rehm
markusrehm is on a distinguished road
Hi Chris,
can you please explain step by step how to get the branch?
Is the right one
or
origin/feature/fullyIntegradetedRealGasThermo?
I got the following messages:
>git checkout -b feature/fullyIntegradetedRealGasThermo origin/feature/fullyIntegradetedRealGasThermo
fatal: git checkout: updating paths is incompatible with switching branches.
Did you intend to checkout 'origin/feature/fullyIntegradetedRealGasThermo' which can not be resolved as commit?
>git pull
You asked me to pull without telling me which branch you
want to merge with, and 'branch.origin/feature/realGasThermo.merge' in
your configuration file does not tell me, either. Please
specify which branch you want to use on the command line and
try again (e.g. 'git pull <repository> <refspec>').
See git-pull(1) for details.
If you often merge with the same branch, you may want to
use something like the following in your configuration file:
[branch "origin/feature/realGasThermo"]
remote = <nickname>
merge = <remote-ref>
[remote "<nickname>"]
url = <url>
fetch = <refspec>
See git-config(1) for details.
Thanks a lot. Markus
markusrehm is offline   Reply With Quote
Old   October 29, 2012, 03:06
Christian Lucas
Follow this explanation (this is what I did)
http://gugod.org/2008/12/git-checkout-remote-branch/
Have a look at
you can find the name of the branch, the changes in the branch ... there. The name is:
Kind Regards,
Christian
Old   October 30, 2012, 18:49
Markus Rehm
Hi Chris,
you are right. So that is what I did (again):
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext
cd OpenFOAM-1.6-ext
git checkout -b feature/fullyIntegratedRealGasThermo origin/feature/fullyIntegratedRealGasThermo
Ok thanks for your patience.
Markus
Old   October 31, 2012, 03:23
Christian Lucas
if you have the time, I would like to get a response regarding the code (problems, suggestions, ...)
Regards,
Christian
Old   November 26, 2012, 17:55
magazoni
magazoni is on a distinguished road
Hi everyone,
I'm trying to install freesteam and I had some problems with it. Does anybody have a tutorial in how to install the freesteam package?
Chris Lucas,
Is it possible to simulate superheated steam and supercooled steam using your code?
Best regards,
Felipe Magazoni
magazoni is offline   Reply With Quote
Old   November 27, 2012, 03:10
Christian Lucas
have a look at the freesteam page, you can find the limits, in which the code works, there. The code works with superheated and subcooled steam.
Have you looked at the README file in the tutorial case I provided for freesteam (in OpenFOAM/tutorials/compressible/rhoPisoFOAM/RAS/IAPWS97_pipe)?
Have you installed all the required components for freesteam as stated in the README file in freesteam?
Could you post the error?
Kind Regards,
Christian
Old   December 3, 2012, 05:49
magazoni
Hi Chris Lucas, thanks for help me.
Now, the freesteam package is correctly installed, but I installed it in the folder '/opt/freesteam'. The libfreesteam.so is not in a folder where OpenFOAM finds ($WM_PROJECT_DIR/lib/linux64GccDPOpt). Must I install the freesteam package in another folder?
After I tried to compile the IAPWS package and there are some errors,
cluster@node0:~/OpenFOAM/OpenFOAM-1.6-ext/src/thermophysicalModels/externalMedia/IAPWS_Waterproperties$ wmake libso
/home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileOptions:37: /home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc46/general: No such file or directory
make: *** No rule to make target `/home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc46/general'.  Stop.
/home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:39: /home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/rules/linux64Gcc46/general: No such file or directory
/home/cluster/OpenFOAM/OpenFOAM-1.6-ext/wmake/MakefileFiles:40: linux64Gcc46DPOpt/options: No such file or directory
make: *** No rule to make target `linux64Gcc46DPOpt/options'.  Stop.
wmake error: file 'Make/linux64Gcc46DPOpt/objectFiles' could not be created
Best regards,
Felipe Magazoni
water properties in supercritical region Naveen CFX 2 April 14, 2009 14:45
standard water properties Thilip Kumar CFX 1 September 20, 2008 10:51
water vapour properties manoj korde FLUENT 4 June 2, 2006 01:47
shallow water VS deep water Paul Main CFD Forum 10 August 30, 2004 11:56
properties of water ? mp Main CFD Forum 0 March 5, 2003 04:41
