August 28, 2008, 02:34 |
Hello everyone,
for applyin
Hannes Kröger
Rep Power: 18 |
Hello everyone,
for applying a numerical integration algorithm in postprocessing, I need my fields on a tetrahedral mesh. I thought of doing this by mapping the fields on a tetPolyMeshFaceDecomp-Mesh. Creating such a mesh is not the problem, but I don't know how to map my volVectorFields to tetPointVectorFields. Is there a quick way of doing this? I found the tetPolyMeshMapper class, but I'm not sure if this could be applied. Thanks, Hannes
silentdynamics GmbH - http://silentdynamics.de open source CAE software solutions & support |
August 28, 2008, 03:27 |
Hannes,
check these:
- v
Tommaso Lucchini
Rep Power: 17 |
Hannes,
check these: - volPointInterpolation class, and how it is used by the spray class to interpolate the cell center values at the lagrangian position - fvMotionSolver, where the mesh motion calculated in a cell centre is then interpolated at the mesh points positions. hope this can be useful, regards Tommaso |
August 28, 2008, 05:42 |
Thanks for the hint, Tommaso.
Hannes Kröger
Rep Power: 18 |
After analyzing the order of the points in the point list (built in "tetPolyMeshFaceDecomp::points()") it seems to me, that I just have to hook up the point-, surface- and cell fields after another to get the tetPointField. Regards, Hannes
[Technical] FvMesh | henry | OpenFOAM Meshing & Mesh Conversion | 4 | February 10, 2018 12:38 |
MultiDirRefinement class Bug on mapping fields | zurdo | OpenFOAM Bugs | 12 | December 17, 2007 04:54 |
Mapping volsurface symmTensor fields after a topological change | jcmasters | OpenFOAM Bugs | 1 | September 4, 2007 13:48 |
Error after mapping fields | alberto | OpenFOAM Pre-Processing | 0 | November 2, 2006 18:47 |
Mapping fields | hsieh | OpenFOAM Pre-Processing | 3 | September 14, 2005 19:56 |
