June 4, 2007, 06:42 |
Dear OpenFOAM users
I am lo
Rep Power: 18 |
Dear OpenFOAM users
I am looking for help on specifying free-surface interface for a 3d geometry. The problem setup is following: I have a shake-flask geometry. I am using interFoam to simulate the mixing of two fluids. Right now I am stuck with how to specify the height of the free surface. In CFX it could be done easily using the step function (ref. tutorial 7 of CFX). I am attaching the figure for clarity. Please help me !!!! Thanks in advance With Kind regards Jaswi |
June 4, 2007, 11:08 |
setField?
Xiaofeng Liu
Rep Power: 17 |
setField?
Xiaofeng Liu, Ph.D., P.E., Assistant Professor Department of Civil and Environmental Engineering Penn State University 223B Sackett Building University Park, PA 16802 Web: http://water.engr.psu.edu/liu/ |
June 4, 2007, 11:17 |
Thanks Liu.
I have looked i
Rep Power: 18 |
Thanks Liu.
I have looked into the dambreak problem and trying with the box option. What i am not sure is that whether one could use the box command to specify a 3d region. box requires min and max. right now my approach is trial and error :-). If you please know how box works then please help Kind Regards Jaswi |
June 4, 2007, 11:54 |
In setField you specify the co
Joakim Möller
Rep Power: 17 |
In setField you specify the coordinates of the boxdiagonal. For example, if you specify the coordinates of a unitbox centered at origo you would do
(-0.5,-0.5,-0.5) (0.5,0.5,0.5) If your box can enclose the region of interest than this should be straight forward. Good luck /Joakim |
June 5, 2007, 05:30 |
Thanks a lot Joakim. It works
Rep Power: 18 |
Thanks a lot Joakim. It works !!!!. Just one last doubt :-)...
The domain is cylindrical and the box command is rectangular. I am specifying a box with the size a little larger than my cylinder. Does setField works on the set : (cylinder) Intersection (box) ---- Also i have seen some people using funkySetField. Did u ever come across it !!!. With box command the interface is not very sharp and i am just wondering if funkySetField will give sharper interface. I am just a bit short of time to give it a try for now :-) Thanks once again. U saved my life :-D With Kind Regards Jaswi |
June 5, 2007, 05:44 |
Hi Jaswi
Yes it works fine.
Joakim Möller
Rep Power: 17 |
Hi Jaswi
Yes it works fine. I have never tried the funkySetField. Hope things works for you. Regards /Joakim |
June 5, 2007, 07:20 |
Hi Jaswi!
@funkySetFields:
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Jaswi!
@funkySetFields: I don't know what you mean with sharp. With funkySetField . yourCase -field gamma -condition "pos().z<0" -expression "1." you would get a partially filled geometry. The "problem" (and I think the same is true for setFields with the box option) is that the condition is only evaluated for the centers of the cells. So if the cell layer around z==0 is not "parallel" to the xy-plane you might get a "ragged" interface (no partially filled cells). So actually it produces a "sharper" interface than is desirable for that case
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
June 5, 2007, 08:50 |
Thanks a lot Bernhard
shall
Rep Power: 18 |
shall give it a try :-) Regards Jaswi PS: Bernhard I am posting a further query. Please take a look at your convenience. |
August 20, 2008, 12:10 |
I download "funkSetfiel
#9 |
feng wang
Rep Power: 17 |
I download "funkSetfields" from the wiki page, when I try to compile it, I run into erros: //*************** ./ValueExpressionDriver.H:22: error: incomplete type 've::ValueExpressionParser' used in nested name specifier ./ValueExpressionDriver.H:22: error: 'yylval' was not declared in this scope ./ValueExpressionDriver.H:22: error: expected primary-expression before '*' token ./ValueExpressionDriver.H:22: error: 'yylloc' was not declared in this scope ./ValueExpressionDriver.H:22: error: expected primary-expression before '&' token ./ValueExpressionDriver.H:22: error: 'driver' was not declared in this scope ./ValueExpressionDriver.H:22: error: initializer expression list treated as compound expression ValueExpressionParser.tab.cc: In member function 'virtual int yy::ValueExpressionParser::parse()': ValueExpressionParser.tab.cc:409: error: 'velex' cannot be used as a function In file included from ValueExpressionParser.yy:63, from ./ValueExpressionDriver.H:11, from ValueExpressionLexer.ll:3: ./ValueExpressionDriverLogicalTemplates.H:7: error: expected initializer before '<' token ./ValueExpressionDriverLogicalTemplates.H:13: error: expected initializer before '<' token ./ValueExpressionDriverLogicalTemplates.H:48: error: invalid use of incomplete type 'struct ValueExpressionDriver' ValueExpressionParser.yy:27: error: forward declaration of 'struct ValueExpressionDriver' ./ValueExpressionDriverLogicalTemplates.H:74: error: invalid use of incomplete type 'struct ValueExpressionDriver' ValueExpressionParser.yy:27: error: forward declaration of 'struct ValueExpressionDriver' ./ValueExpressionDriverLogicalTemplates.H:105: error: invalid use of incomplete type 'struct ValueExpressionDriver' ValueExpressionParser.yy:27: error: forward declaration of 'struct ValueExpressionDriver' ./ValueExpressionDriverLogicalTemplates.H:133: error: invalid use of incomplete type 'struct ValueExpressionDriver' ValueExpressionParser.yy:27: error: forward declaration of 'struct ValueExpressionDriver' In file included from ValueExpressionLexer.ll:3: ./ValueExpressionDriver.H:22: error: incomplete type 've::ValueExpressionParser' used in nested name specifier ./ValueExpressionDriver.H:22: error: 'yylval' was not declared in this scope ./ValueExpressionDriver.H:22: error: expected primary-expression before '*' token ./ValueExpressionDriver.H:22: error: 'yylloc' was not declared in this scope ./ValueExpressionDriver.H:22: error: expected primary-expression before '&' token ./ValueExpressionDriver.H:22: error: 'driver' was not declared in this scope ./ValueExpressionDriver.H:22: error: initializer expression list treated as compound expression lex.ve.c:6945: error: redefinition of 'int velex' ./ValueExpressionDriver.H:22: error: 'int velex' previously defined here lex.ve.c:6945: error: incomplete type 've::ValueExpressionParser' used in nested name specifier lex.ve.c:6945: error: 'yylval' was not declared in this scope lex.ve.c:6945: error: expected primary-expression before '*' token lex.ve.c:6945: error: 'yylloc' was not declared in this scope lex.ve.c:6945: error: expected primary-expression before '&' token lex.ve.c:6945: error: 'driver' was not declared in this scope ValueExpressionParser.tab.cc: In member function 'unsigned char yy::ValueExpressionParser::yytranslate_(int)': ValueExpressionParser.tab.cc:2141: warning: use of old-style cast ValueExpressionParser.yy: At global scope: ValueExpressionParser.yy:327: error: expected unqualified-id before '&' token ValueExpressionParser.yy:327: error: expected ',' or '...' before '&' token ValueExpressionParser.yy:327: error: invalid use of incomplete type 'struct ve::ValueExpressionParser' //************************ Could anyone give me some ideas? BTW:I read the "README" file, it says it works for OF 1.4, but I am now using 1.4.1-dev Kind regards feng |
August 20, 2008, 13:27 |
I get some idea from th
#10 |
feng wang
Rep Power: 17 |
I get some idea from the following link, and the problem is solved..... http://www.cfd-online.com/OpenFOAM_D...ges/1/368.html kind regards feng |
Problem in Initializing Blocking for 2d geometry | nitin Dewangan | CFX | 6 | October 24, 2008 01:03 |
Effects of turbulence on freesurface | sek | OpenFOAM Running, Solving & CFD | 4 | March 22, 2008 21:48 |
Need following paper about freesurface analysis | Morteza | Main CFD Forum | 1 | July 13, 2006 13:32 |
Difficult BCs about Freesurface Simulation by VOF | Yongguang Cheng | FLUENT | 0 | September 19, 2003 07:39 |
FreeSurface simulation | Chengxuan Fu | Siemens | 0 | January 27, 2001 06:08 |
