August 12, 2008, 11:51 |
My current project: MovingBoun
Johan Lorentzon
Rep Power: 23 |
My current project: MovingBoundary solver have shown not move the grid! the following code is used,
Main code: // 1/dt scalar factor=1/(runTime.deltaT().value()); // loop over all boundary points forAll(fluidMesh.localPoints(),fluidI) { // get displacement vector shared::icofsi_db.get_displacement(fluidI,patchU[fluidI]); // calculate dU this gives the motionU on boundary patchU[fluidI]=factor*patchU[fluidI]; } // move mesh, using solver spec by dynamivMesh mesh.movePoints(motionPtr->newPoints()); #include file: autoPtr<foam::motionsolver> motionPtr = motionSolver::New(mesh); tetPointVectorField::GeometricBoundaryField &motionU=const_cast<tetpointvectorfield&>(mesh.obj ectRegistry::lookupObject<tetp ointvectorfield>("motionU")).boundaryField(); Foam::vectorField &patchU=refCast<foam::vectorfield>(motionU[MovingBoundary]); The result is that the fluid mesh didnt move accordingly the displacement vector i provided as above. Any clue to the error? Then i use the FEM solver in OF 1.3 which i am not about to use anymore ( xn=x0+dt*dU, velocity solver). Anyone who can give me anyhint in what solver to use to solve above problem in official 1.4.1/1.5 ( not dev), the case i am working transfer a displacement vector on each point on the moving fluid boundary, then i want to use motionSolver to adjust the mesh in a robust manner since the movement is unknown/moderate large. Further i truly would appriciate a piece of code that i could use as starting point for my implementation. Thank you for helping me! PS. I have searched through whole forum and found no help! However,I have seen the excellent studies of mesh movement. Guessing laplacefacedecompistion should be used but i have no clue how to implement it! |
Slip Boundary Condition for Moving Boundary | Shukla | Main CFD Forum | 3 | November 11, 2005 16:02 |
moving boundary | Wu Guojiang | FLUENT | 2 | August 6, 2005 16:34 |
Moving Boundary | andreis | FLUENT | 0 | April 14, 2005 00:36 |
moving boundary in CFX 5.7 | Gary Wang | CFX | 7 | February 11, 2005 03:28 |
moving boundary | Amir Khanlou | FLUENT | 0 | March 9, 2003 13:04 |
