June 2, 2008, 15:15 |
Something strange happend, whe
Sebastian Gatzka
Rep Power: 20 |
Something strange happend, when I tried to run this rather big case (10^6 cells).
http://therealsega.th.funpic.de/open...n3DSend.tar.gz The solver just quit with the message "killed" after the first timestep. When running in paralle I got this additional message: mpirun noticed that job rank 1 with PID 5466 on node M1530 exited on signal 15 (Terminated). 1 process killed (possibly by Open MPI) Whats that?
Schrödingers wife: "What did you do to the cat? It's half dead!" |
June 2, 2008, 15:21 |
If I use just 40 % of the abov
Sebastian Gatzka
Rep Power: 20 |
If I use just 40 % of the above number of cells the solver is running ...
How is that? Not enough memory?
June 2, 2008, 15:54 |
Hi
No problems in time-ste
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi
No problems in time-stepping on my machine. 2GB of memory. The solver uses up to 900MB and including OS-uses it goes to 1200MB. / Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
June 2, 2008, 17:12 |
Hi Sebastian,
You ran out
Hrvoje Jasak
Rep Power: 33 |
Hi Sebastian,
You ran out of memory and the operating system killed your process (in self defence) Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
June 2, 2008, 17:33 |
Yes, that was right!
If you r
Sebastian Gatzka
Rep Power: 20 |
If you remember, I'm using a virtual environment to run my linux system. I just doubled the the amount of memory and now it's working. Thanks!
parallel fluent runs being killed at partitioing | Ben Aga | FLUENT | 3 | June 8, 2012 10:40 |
segregated solver vrs coupled solver | sm | FLUENT | 0 | November 6, 2007 01:24 |
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver | dandes | OpenFOAM Pre-Processing | 0 | March 22, 2006 21:06 |
Killed by signal 8 after first timestep | matthias | OpenFOAM Running, Solving & CFD | 0 | December 9, 2005 08:06 |
coupled solver / uncoupled solver | Jaan Unger | Main CFD Forum | 0 | September 3, 2002 08:30 |
