TimeVaryingUniformFixedValue does not work as a pressureInlet with sonicLiquidFoam
Old   May 13, 2008, 10:12
Default I also have the exactly simila
Nishant
nishant_hull is on a distinguished road
I also have the exactly similar problem with rhoSonicFoam...!!!
Though the inlet.dat file is there at the same location. can anybody please find out where we should look to make it correct. because we could not be able to use a complete solver for our specific work.
regards,
Nishant
Thanks and regards,
Nishant
nishant_hull is offline   Reply With Quote
Old   May 13, 2008, 11:40
Default Hello there, A good day to
Philippose Rajan
philippose will become famous soon enough
Hello there,
A good day to you :-)!
As far as I remember right, when specifying the file for the timeVaryingUniformFixedValue boundary condition, OpenFOAM assumes that the folder to find the file, is the folder from where you ran the simulation command.... for example...
if my simulation is being run from the folder:
/home/user/OpenFOAM/user-1.4.1/run/
and the simulation case is called:
test_v01
and if you go to the above run folder, and use the following standard line to start your simulation:
sonicLiquidFoam . test_v01
then, the file "inlet.dat" should be in the "run" folder, and not somewhere within the simulation case folders.
If you place the file "inlet.dat" in the root folder of your simulation case by changing the condition to:
F1
type timeVaryingUniformFixedValue;
timeDataFileName "./test_v01/inlet.dat";
value uniform 1e+5;
and then try running the simulation as I mentioned earlier, things would work.
Moral of the story... As far as I have understood, the safest is to specify the file in the boundary specifiation, is to give the complete absolute path... then you can start the simulation from any folder.
Hope this provides some help... if not, let me know...
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   May 13, 2008, 12:20
Default well.. Thanks for the reply Ph
Nishant
well.. Thanks for the reply Philippose.
I am already doing as you suggested. Its working fine with rhopsonicfoam solver. But the rhoSonicFoam solver particularly is not recognizing the file's format, i think.
the format of the file i am using is:
t0 p0
tn pn
This format work fine with rhopSonicFoam solver.
however, if i remove the file inlet.dat from the directory then it complains that there is no inlet.dat file but currently its not giving the name.. just a "".
nishant
Thanks and regards,
Nishant
Old   May 13, 2008, 21:29
Default Hi. Thanks for your reply, Phi
Martin/Run DU
chnrdu is on a distinguished road
Send a message via Skype™ to chnrdu
Hi. Thanks for your reply, Philippose.
It doesn't work with sonicLiquidFoam. I tried your filename format, it prompted the same:
--> FOAM FATAL IO ERROR : file "" does not exist
file: at line 1.
From function IFstream::operator()
in file db/IOstreams/Fstreams/IFstream.C at line 171.
FOAM exiting
I did place the data file in all the subdirectories of the case, and also copied it to the same father-directory of the case.
Martin/Run DU
rdu
Martin/Run Du
chnrdu is offline   Reply With Quote
Old   May 14, 2008, 09:05
Default Martin, It works well with
Nishant
Martin,
It works well with rhopSonicFoam, if that solver of any help for your problem. It doesnot work with rhoSonicFoam or rhoLiquidFoam.
regards,
Nishant
Thanks and regards,
Nishant
Old   May 21, 2008, 08:54
Default Hi, Nishant, I find the cause.
Martin/Run DU
Please see www.durun.cn/?p=364
rdu
Martin/Run Du
TimeVaryingUniformFixedValue holger_marschall OpenFOAM Running, Solving & CFD 4 August 10, 2013 14:47
TimeVaryingUniformFixedValue BC in foam 15 nzy102 OpenFOAM Running, Solving & CFD 5 August 19, 2008 08:08
TimeVaryingUniformFixedValue with sonicLiquidFoam Bugs amp Fixes chnrdu OpenFOAM Bugs 1 May 21, 2008 09:52
Changing area with a random value of pressureinlet M-Ray FLUENT 0 May 16, 2008 02:48
PressureInlet christian OpenFOAM Running, Solving & CFD 1 February 13, 2008 15:03
