I am wondering if anyon
I am wondering if anyone has the same error when trun on wall contact angle: ------------------------------------ Exec : interFoam . damBreak Date : May 07 2006 Time : 18:38:02 Host : linux PID : 7709 Root : /home/phsieh/OpenFOAM/phsieh-1.3/run/tutorials/interFoam Case : damBreak Nprocs : 1 Create time Create mesh Selecting dynamicFvMesh staticFvMesh Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian --> FOAM FATAL ERROR : Not implemented From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch& p, const Field<type>& iF) in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 50. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::defaultFvPatchField<double>::defaultFvPatchF ield(Foam::fvPatch const&, Foam::Field<double> const&) Foam::fvPatchField<double>::addpatchConstructorToT able<foam::defaultfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::Field<double> const&) Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::Field<double> const&) interFoam [0x467ff6] interFoam [0x489bee] interFoam [0x43ace5] __libc_start_main __gxx_personality_v0 Aborted ----------------------------- Pei |
What is your gamma boundary ca
What is your gamma boundary called?
It should one of the following: constantGammaContactAngle dynamicGammaContactAngle timeVaryingGammaContactAngle check interFoam/interfaceProperties/gammaContactAngle for details. |
Hi, Eugene,
Thanks for the
Hi, Eugene,
Thanks for the reply. It works after I manually change from gammaContactAngle to constantGammaContactAngle. However, if I use FoamX to set the case up, I only get "gammaContactAngle" - cannot specify whether it is constant or dynamic or timeVarying. Is it correct? Am I missing something when using FoamX? (this is not a problem in version 1.2). Pei |
Post this to the Bug forum.
Sorry to re-open this one but
Sorry to re-open this one but I have exactly the same problem, but I dont understand Eugene's answer to it.
I checked to find a file or directory called interFoam/interfaceProperties/gammaContactAngle (under applications/solvers/multiphase) but in my version (OpenFoam 1.4) I couldnt find anything there. I tried changing "gammaContactAngle" to "constantGammaContactAngle" in the gamma file at time 0 - but that just produced another error because it didnt recognise the expression constantGammaContactAngle If somebody could indulge a beginner like me and take me through what Pei did to get his case working I would be very grateful. Many thanks Mark |
Hi, Mark,
Send me your emai
Hi, Mark,
Send me your email address. I can send you a simple case file to see if you can run it without any problem. Pei phsieh2005@yahoo.com |
Hi, Mark,
Did you receive t
Hi, Mark,
Did you receive the test case I sent you? Did that resolve your issue? Pei |
Hi, Pei-Ying Hsieh.
I have th
Hi, Pei-Ying Hsieh.
I have the same problem. If are there no problem , I want sample-case file.....OK? Giro |
I have the same problem.And i still can't solve it.I hope anyyone who did out can tell me. But i don't think it is a bug. In the dynamicGammaContactAngleFvPatchField.C,it said : if "utheta" < SMALL {return Theta0}. I think in this time , it uses the constantgammacontactAngle model . else using the dynamicgammacontactAngle model ! |
