Combustion temperature
Old   January 17, 2008, 01:05
Default I simulate the propane-air mix
yu_korogi
I simulate the propane-air mixtures combustion with XiFoam.
I'd like to simulate the laminar homogeneous flame propagation, so I set /constant/turbulenceProperties
turbulenceModel laminar;
turbulence off;
and set the initial pressure P=101300;
then simulated.
But the temperatures are less than 500K at any time.they're too low.I expect they're around 2000K.
Why?Could you give me some advice?
Old   May 6, 2008, 04:00
Default What is ur initial boundary va
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
What is ur initial boundary value for the temperature. If the temperature is too low or you have no ignition-source the species will not burn.
So either set the initial value for the internal field to a temperature where you now it will burn e.g
"internalField uniform 2000;"
Or look into diselFoam how to add an ignition source.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
urgent: Combustion constant temperature Tim Siemens 3 June 29, 2008 18:12
High Combustion Temperature in the EBU model Mehdi Siemens 0 April 24, 2006 05:53
Xoodles temperature change without combustion hannes OpenFOAM Running, Solving & CFD 5 October 17, 2005 16:31
Combustion gas temperature in oil-fired furnace HasriL FLUENT 1 July 1, 2005 10:13
Decreasing temperature of combustion Jacek FLUENT 5 February 18, 2002 00:45
