dear Friends,
I have highly
dear Friends,
I have highly nonlinear problem that I want to solve in OF. please help me with implementation. This problem is in steady state derived from system where three forces act on fluid (capillary, gravity and viscosity forces). I simplified problem to be tackable numerically (the equation is dimmensionless form). The continuity equation is expressed as: div(A*u)=0 (1) and u as: u= - K/sqrt(A) grad A - g/mag(g) A + v (2) where: (variables given in the order name - meaning, unit; type of variable(field) in OF) u - liquid velocity, dimless; volVectorField defined on mesh v - gas velocity, dimless; volVectorField defined on mesh K - constant , m^-1 ; dimensionedScalar A - area , dimless; volScalarField defined on mesh g - gravity const. , ms-1 ; dimensionedVector From those two equations i would like to calculate A. when i plug (2) to (1), i get: div(-K*sqrt(A) grad A - g/mag(g) A^2 + A v )=0 (3) if we try to expand div we get: - 0.5K/sqrt(A) grad A grad A - K*sqrt(A) laplacian(A) - 2A g/mag(g) grad(A) + A div(v) + v grad(A)=0 (4) as you see in equation (4) we have almost no implicit terms. How to tackle the problem? How to implement this in OpenFoam? Where to look for a solutions of a similar problems? Any suggestions appreciated. Thank you in advance. /Rafal one thing more Significance of terms in equation (3). (- K*sqrt(A) grad A) - plays key role near 2 out of 5 of the boundaries in the rest of the domain neglegible. (- g/mag(g) A^2) - significant in most of the domain A v - an order less than previous |
Hi Rafal!
At first the equa
Hi Rafal!
At first the equations looked to me like something I have seen before (two phase flow in porous media), but then again they didn't. Questions I have at a first glance: - dimensionless velocities? (I know physicicsts do it all the time, usually by normalizing with c, but engineers?) - the relative densities of liquid and gas go into K? - which leads to the next question: both (gas and liquid) are incompressible? - in (2) you wanted to write K/(sqrt(A) grad(A))? Otherwise I can't match the dimensions. - You are looking for a stationary solution? I think it can be done in OF, but I'm not aware of a solver in the distribution that is similar to your problem. |
Hi Bernhard,
Thanks for ans
Hi Bernhard,
Thanks for answer. I didn't want to provide to much details about the system not to complicate the problem to much. Good intuition. Those equation describe motion of liquid in a soap foam (drainage of water from a foam due to gravity), which is similar to flow in porous media in a sens that we have also channels in which our fluid flows through static material. In this case material consist of close packed air bubbles moving upwards (velocity of gas v in eq.(2)). Channels are located in the junction of three bubbles. First of all word of apology. I mistook dimension of K which is m (and NOT m-1 as i wrote above), sorry for confusion. To give you more details about the equation and provide more comprehensive description of the problem i have prepared it in attachment with derivation of equations. http://www.cfd-online.com/OpenFOAM_D...hment_icon.gif derivation.dvi Velocity of gas (v) i assumed is influenced by water drainage. v is calculated separately (done this before). in this discussion we can assume is known. I assume also that both fluids (gas,liquid) are incompressible. I am looking for steady state solution. Why normalisation to get dimensionless velocities? A (cross-section area through channel) in case of foam is in order of 10-5 with velocities in the order of 10-1 may give numerical problems. I do not stick to this normalization it is only idea i read somewhere about. If it is a problem i can remove it. Do not hasitate to ask for more details. All help is appreciated. Thank you in advance for all suggestions and i invite everyone to discussion. rafal |
IS: Velocity of gas (v) i assu
IS: Velocity of gas (v) i assumed is influenced by water drainage
SHOULD BE: Velocity of gas (v) i assumed is NOT influenced by water drainage |
hi all,
i am supposed to modi
hi all,
i am supposed to modify a code into a dimensionless one.how do i go about it? thanks in advance |
