sonicFoam - simulation stop for negative temperature - are my parameters wrong ?
Old   December 24, 2018, 17:08
Default sonicFoam - simulation stop for negative temperature - are my parameters wrong ?
Jad.L. is on a distinguished road
Dear Foamers,
I am using openFoam v.6 and the solver sonicFoam for k-omega SST simulation.
My simulation stops after few loop due to a negative temperature (in Kelvin ). I think I have a trouble with my parameters. Could someone please check it?
About the simulation :
A cylinder of 100 mm length and with a 50 mm diameter. There is one inlet and one outlet at each part of the cylinder. This cylinder is under vacuum 0.1 Pa. The inlet will release 1.5e7 Pa (150 bar) and the outlet does nothing for now.
alphat
alphat = thermal conductivity / heat capacity
For H2 , alphat = 0.18/14300 = 1.2587e-5
internalField   uniform 0.000012587;
boundaryField
    Inlet
        type            calculated;
        value           uniform 0.000012587;
    Outlet
        type            calculated;
    Pipe
        type            compressible::alphatWallFunction;
k
For the kinematic energy k, I found 4.14e-22 ( I used k=3/2*Boltzman cst* Temperature ) But this result seems weird.
I assume to have supersonic flow, I should have a velocity around U=750 m.s-1
Then I used the formula k = 3/2 (U*I) from CFD wiki . k = 16537
Is it correct to assume U= 750 and sound Velocity = 300 for my case ?
internalField   uniform 1;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 16537;
    Outlet
        type            inletOutlet;
        inletValue      uniform 1;
        value           uniform 1;
    Pipe
        type            kqRWallFunction;
        value           uniform 1;
nut
 internalField   uniform 0;
boundaryField
    Inlet
        type            calculated;
        value           uniform 0;
    Outlet
        type            calculated;
        value           uniform 0;
    Pipe
        type            nutkWallFunction;
        value           uniform 0;
omega
from the formula given in CFD wiki, omega =128/1.9e-4 =0.024
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 0.024;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 0.024;
    Outlet
        type            inletOutlet;
        inletValue      uniform 0.024;
    Pipe
        type            omegaWallFunction;
p
internalField   uniform 0.1;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 15000000;
    Outlet
        type            waveTransmissive;
        field           p;
        psi             thermo:psi;
        gamma           1.3;
        fieldInf        0.1;
        lInf            1;
        value           uniform 0.1;
    Pipe
        type            zeroGradient;
T
internalField   uniform 20;
boundaryField
    Inlet
        type            fixedValue;
        value           uniform 20;
    Outlet
        type            inletOutlet;
        inletValue      uniform 20;
        value           uniform 20;
    Pipe
        type            zeroGradient;
U
internalField   uniform (0 0 0);
boundaryField
    Inlet
        type            fixedValue;
        value           uniform (750 0 0);
    Outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
        value           uniform (0 0 0);
    Pipe
        type            noSlip;
Jad.L. is offline   Reply With Quote
LES simulation parameters manju819 OpenFOAM Running, Solving & CFD 5 November 6, 2016 08:07
udf error srihari FLUENT 1 October 31, 2016 14:18
Temperature stratification simulation in CFX marble CFX 0 May 25, 2016 17:53
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM 0 December 16, 2010 11:46
Unexpected large decrease in Total temperature across the shock using sonicFoam JLight OpenFOAM Running, Solving & CFD 0 December 15, 2010 05:47
