Implemeting ducted fan
Old   March 17, 2008, 15:07
Default Hello, I am new to OpenFOAM
Hiraku
hiraku is on a distinguished road
I am new to OpenFOAM and have been wondering how to model a ducted fan in hover. If anyone could advise me on how to model it, I am grateful.
At this moment, I would like to keep it simple without having to use a moving mesh and just use a in/outlet perhaps?
Regards,
hiraku
hiraku is offline   Reply With Quote
Old   March 17, 2008, 16:36
Default I'd start with a torus having
Doug Baldwin
gdbaldw is on a distinguished road
I'd start with a torus having an inlet and outlet patch at the hole in the middle. On the inlet fix the velocity, and on the outlet fix the static presure to an appropriate value for the inlet velocity. I'd initially make a single far-field patch with a constant pressure. After that works, you could properly shape the duct and add inlet/outlet at the far-field to represent wind.
Doug
gdbaldw is offline   Reply With Quote
Old   March 17, 2008, 17:13
Default Clarification...duct inlet (wh
Doug Baldwin
Clarification...duct inlet (which is an outlet of the computational domain) has constant pressure, and duct outlet (which is an inlet to the computational domain) has constant velocity.
Old   March 19, 2008, 14:00
Default Thank you for your advice.
Hiraku
I have created a torus with surface in the middle of the hole using SALOME. The torus is contained in a larger cube. This was meshed and exported as .unv Then I used ideasUnvToFoam to convert the file for OpenFOAM. I wasn't so sure which solver to used so, decide to use icoFoam since it doesnt require alot of set up. Unfortunately, the results do not make sense; with velocity and pressure running random.
The boundaries of the cube and the torus are set as "wall". The inlet and outlets are set as you have advised; torus outlet as "inlet" and torus inlet as "outlet". The rest of the parameters are the default of the tutorial contained in icoFoam with the exception of pressure (1e5 Pa) and all of controlDict.
I do not know what the problem could be. I feel that the meshes maybe too large or that the I have set something incorrectly.
Currently, I am trying to use a finner mesh. Any advice is appreciated.
Regards,
hiraku
Flow recirculation around a ducted fan Jane Main CFD Forum 2 January 24, 2012 05:17
Ducted propeller, Boundary conditions Johannes FLUENT 0 May 7, 2008 09:21
A Basic Question on ducted Flows! CFD User Main CFD Forum 4 January 8, 2005 06:17
Question about flow in ducted fan in another duct Jane FLUENT 0 June 21, 2004 13:57
CFD for Ducted Fans Nash Main CFD Forum 0 August 1, 2003 05:52
