January 15, 2008, 13:01 |
Does anyone know how to go abo
Laurence Griffiths
Rep Power: 17 |
Does anyone know how to go about adding a steady time stepping algorithm to the sonicFoam solver, or if its at all possible?
Is it possible to just replace PISO with SIMPLE algorithm, or is it not quite that easy? |
March 8, 2008, 10:28 |
A small help.
Hi everybody,
N S Prasad
Rep Power: 17 |
A small help.
Hi everybody, I have been writing a finite Difference code for flow through a divergent section. The geometry is simple. The lower boundary (wall) is a horizontal line 2mm long. The left boundary is a vertical line (extrapolated outlet) of length 0.4 mm. the right boundary (supersonic inlet) is a vetical line 0.3 mm long. the top boundary is an inclined line (wall) connecting left and right. The inlet is at 1000 m/s, 101325 pa and 298 K. fluid is ideal air. Domain is split 200 times along x axis, evenly, and 100 times along y axis , evenly. the pressure contour from sonicFoam is given below. and so is the output from my code. http://enginesei.blogspot.com/2008/0...-contours.html can you give your comments about which one is more correct ?? Thanks, Prasad. |
SonicFoam | stvtiegh | OpenFOAM Running, Solving & CFD | 1 | June 26, 2008 09:30 |
SonicFoam error | 21kalee | OpenFOAM Running, Solving & CFD | 6 | January 2, 2008 14:00 |
SonicFoam 141dev changes what do they mean | mike_jaworski | OpenFOAM Running, Solving & CFD | 0 | December 30, 2007 15:55 |
New solver from sonicFoam | dimi | OpenFOAM Running, Solving & CFD | 2 | December 5, 2007 18:08 |
Help me with sonicFoam | marcelo | OpenFOAM Running, Solving & CFD | 6 | December 10, 2005 02:57 |
