Error Reading date file
Old   June 17, 2005, 22:42
Default I want to make a transient sim
Martin/Run DU
chnrdu is on a distinguished road
Send a message via Skype™ to chnrdu
I want to make a transient simulation of a pipe. on one end, I make the pressure as a function respect to time and write to a file as:
t0 p0
t1 p1
tN pN
but when I compute it, there is a error:
Reading field p
--> FOAM FATAL IO ERROR : IOstream::check(const char* operation) : error in IOstream "inletPressure.dat" for operation Istream::operator()
file: inletPressure.dat at line 1.
Function: IOstream::check(const char* operation) const
in file: db/IOstreams/IOstreams/IOcheck.C at line: 54.
FOAM exiting
what about the error? How to correct?
Thanks in advance.
rdu
Martin/Run Du
chnrdu is offline   Reply With Quote
Old   June 20, 2005, 05:11
Default 1. is the file present? 2.
Mattijs Janssens
2. what boundary condition are you using? timeVaryingUniformFixedValue?
Does it work if you remove the bracket pair? I think this b.c. reads an unformatted 2 column file to make it easy to use externally generated data.
Old   June 21, 2005, 00:26
Default Yes, I use the timeVaryingUnif
Martin/Run DU
Yes, I use the timeVaryingUniformFixedValue.
I removed the bracket pair. there is the same problem. You mean the unformatted 2 column file as binary file?
rdu
Martin/Run Du
Old   June 21, 2005, 05:22
Default Sorry, never used it. I found
Mattijs Janssens
Sorry, never used it. I found the actual reading gets done in sampling/lnInclude/graph.C where it constructs the graph from an Istream.
Looks like the format is
"title"
"x" "y"
0.0 54
0.1 24
0.2 35
or something similar.
Old   June 21, 2005, 08:24
Default The format of the file read by
henry is on a distinguished road
The format of the file read by timeVaryingUniformFixedValue is
t0 p0
t1 p1
tN pN
but the error message you get suggests that the file cannot be found, i.e. is not in the location you specify in the boundary condition details.
henry is offline   Reply With Quote
Old   June 21, 2005, 08:37
Default Thank u, H. Weller. I find
Martin/Run DU
Thank u, H. Weller.
I find the error that u pointed out. I located it in the 0/p fold. i copy it to the caseroot fold. Now It works well.
rdu
Martin/Run Du
Old   September 27, 2005, 15:05
Default Hi, Foam don't accept this i
olivier Petit
olivier is on a distinguished road
Foam don't accept this instruction.
How can I do this in Foam
FILE *fp;
int i;
fp=fopen("filePr","r+");
for(i=0;i<=size;i++)
fscanf(fp,"%f %f %f %f",&pr[5*i],&pr[5*i+1],
&pr[5*i+2],&pr[5*i+3]);
fclose(fp);
thanks
olivier is offline   Reply With Quote
Old   September 28, 2005, 04:53
Default IFstream str("filePr"); sca
Mattijs Janssens
scalar a,b,c,d;
str>> a >> n >> c >> d;
Old   July 5, 2006, 09:14
Default Hello For postprocessing pu
Aurelia Cure
aurelia is on a distinguished road
Hello
For postprocessing purpose, I am using ifstream to read a file and calculate something called A, which is then wroten in an other file
fileName fileV="v.dat";
OFstream VFile(fileV);
fileName fileC= "c.dat";
IFstream CFile(fileC);
char a;char b;
double T1;double T2;scalar C1x;scalar C1y;scalar C1z;scalar C2x;scalar C2y;scalar C2z;scalar A;
while(!CFile.eof() )
{ CFile>>T1>>a>>C1x>>C1y>>C1z>>b>>T2>>a>>C2x>>C2y>>C 2z>>b;
A= ...// Here it calculates A
VFile<< T2 << " "<<A<< endl;
It works (read, calculate and write) for all the value in the read-file but then I get the following error:
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: c.dat at line 124.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
I think that it doesn't understand that it is the end of the file, even with the .eof()
Should I close the file (... how?) to avoid this error?
Or should the read-file have something special at the end?
Thanks
Aurelia
aurelia is offline   Reply With Quote
Old   March 6, 2008, 10:52
Default I have a file with the followi
Maka Mohu
maka is on a distinguished road
I have a file with the following format.
y1 u1 v1 w1
y2 u2 v2 w2
yn un vn wn
I know that one can read Field<t> from IStream but how can I read such mixed format to:
scalarField y;
vectorField u;
Is there a way to do it in OpenFOAM or should I write another graph class that accepts such format? thanks.
maka is offline   Reply With Quote
Old   March 3, 2011, 08:11
Paweł Kuczyński
kuczmas is on a distinguished road
Hey Aurelia,
Did you manege to solve you problem? I have got the same error message, when trying to write my data into the file.
Cheers
Best regards
P. Kuczynski.
kuczmas is offline   Reply With Quote
Old   March 3, 2011, 08:18
Paweł Kuczyński
Hey mattijs,
after using your code snippet
scalar a,b,c,d;
in my program I got the following error message:
--> FOAM FATAL IO ERROR:
file: filePr at line 1.
    From function void Istream::getBack(token&)
    in file db/IOstreams/IOstreams/Istream.C at line 38.
FOAM exiting
Do you know what's wrong and how to fix it?
Best regards
P. Kuczynski.
Old   January 29, 2013, 01:57
Bernhard
Bernhard is on a distinguished road
I am encountering the same error message as above. Anyone who knows what I am doing wrong?
Bernhard is offline   Reply With Quote
Old   January 29, 2013, 02:35
Bernhard
So, apparently, the problem is, the I am trying to read four values at once, like
file >> a >> b >> c >> d;
There error-message occurs on the second >> as far as I can see.
My work-around is as follows
file >> a;
if( !file.bad() )
    file >> b >> c >> d;
    // Everything else
which solves my problem.
I don't like the 'niceness' of this solution, so I am open for suggestions.
Error reading trn file OliH CFX 3 March 4, 2010 08:24
Error when reading res file Taewon Seo CFX 1 April 28, 2009 09:09
Error reading msh file ANIL FLUENT 1 January 22, 2009 00:45
error reading file limingtiger Siemens 3 September 21, 2005 20:31
Error while reading mesh file sak FLUENT 3 July 25, 2005 08:28
