you have not recognized progra
you have not recognized programming in C++ using FOAM classes
Hi, Mojtaba
Thanks for your
Hi, Mojtaba
Thanks for your advice. I find myself really lost when hanling FOAM classes, which is my biggest problems in understanding and modifying a solver. My C++ knowledge is in a relative low level and I want to start from the bottom, Could you give some ideas how to do it? All the best Feng |
Dear Feng,
I have written a
Dear Feng,
I have written an intro to programming in OpenFOAM - send me your email address and I'll email it to you (my email address is g.r.tabor@ex.ac.uk) Gavin |
Hi Feng!
In the exchange li
Hi Feng!
In the exchange line write rhoFluid.value()*fluidP instead of rhoFluid*fluidP Have a look at the dimensioned-template to understand why Bernhard |
Dear Gavin
My email addres
Hi, Bernhard,
Now I can com
Hi, Bernhard,
Now I can compile the solver , but the caculation blows off as soon as it is strted, Below is the end of the caulation Time = 1 Moving mesh Correct mesh motion diffusion field. ICCG: Solving for motionUx: solution singularity ICCG: Solving for motionUy: solution singularity ICCG: Solving for motionUz: solution singularity Biggest movement: 4.73178e+173 Bigges divergence 1.09837e+158 Solving flow in mesh1 Mean and max Courant Numbers = nan nan BICCG: Solving for Ux: solution singularity BICCG: Solving for Uy: solution singularity ICCG: Solving for p: solution singularity ICCG: Solving for p: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = nan, global = nan, cumulative = nan ICCG: Solving for p: solution singularity ICCG: Solving for p: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = nan, global = nan, cumulative = nan Solving structure in mesh2 ICCG: Solving for Udispx: solution singularity ICCG: Solving for Udispy: solution singularity Max sigmaEq = inf Max sigmazz = 0 Maximum Displacement: 4.73178e+173 The maximum displacement is terribly wrong. By the way, I set the density of the fluid to be 1000 kg/m^3. All the best Feng |
Hi Feng!
Check the boundary
Hi Feng!
Check the boundary conditions for the mesh motion. If they are all Neumann and no Dirichlet the motion-solver has no fixed point and "shoots" the grid to infinity. Bernhard |
Hi Bernhard!
Thanks for you
Hi Bernhard!
Thanks for your help! In fact, I have set the density of fluid to be 1 kg/m^3 for test, but the caculation still blows up. I am now trying your method, and have not worked it out. By the way, I am just wondering if I replace the original one with solidP[exchange[fI]]=rhoFluid.value()*fluidP[fI]; we all know OF also does the dimension checking, So after I make that change, the dimension on the right side of "=" will also change. The pressure tranfered to the solid structure will have the dimension of N/m^2, not m^2/s^2. I guess that might also be a problem All the best Feng |
Hi Feng!
Dimensions are onl
Hi Feng!
Dimensions are only checked if you do the operations on the whole field. If you do it on a single-element level (like the example above) nothing will be checked (for performance reasons). In other words: you can be as unphysical as you like. Or: You have to ensure yourself, that what you do is correct. Bernhard |
