I have compiled buoy
I have compiled buoyantFoam solver after adding transport equation and included the hCombustionThermo class instead of basicThermo. The compilation has been successful. But for a simple 2D case with one specie the case gives the following error. FOAM FATAL ERROR : attempt to use janafThermo<equationofstate> out of temperature range 200 -> 5000; T = -37.5747#0 Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::specieThermo<foam::janafthermo<foam::perfect gas> >::H(double) const in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libcombustionThermophy sicalModels.so" #3 Foam::hMixtureThermo<foam::reactingmixture>::calcu late() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libcombustionThermophy sicalModels.so" #4 Foam::hMixtureThermo<foam::reactingmixture>::corre ct() in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libcombustionThermophy sicalModels.so" #5 main in "/home/caelinux/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/mechFlow" Actually, the error doesn't make sense to me as the temprature inside the while domain is atleast above 300K and it cannot go below 0 K. There is some problem with the numerics which I am not able to find... I have seen people facing the same problem. I tried to increase the number of orthogonal correctors with no change in the results. I just want to know as what is causing such problems? The mesh is pretty generic... With hex cells. |
