January 10, 2008, 16:14 |
Hi everybody,
To deal with
Frank Bos
Rep Power: 18 |
Hi everybody,
To deal with very very large rotations, plunging rotating wing with angle of attach varying from +60 to -60 degrees, I developed a dynamicFvMesh library using fvSubsetMesh. This library creates two mesh subsets, following constant/polyMesh/sets and defines the motion on both. In such a way I define a mesh subset just around the wing which moves with the wing, and another outside it. The motion of the innermesh is the result of motion definition of the wing patch leaving the outer mesh unchanged. The motion of the outermesh is the result of motion definition of the interface patch. When the motion of the interface and the wing are the same the internal subset mesh moves undeformed with the wing. 2 problems/questions: 1) The problem is the interface. I have two subsets, how do I get the interface appear in /constant/polyMesh/boundary such that I can use that patch in dynamicFvMesh.... 2) If the interface is present in /constant/polyMesh/boundary what boundary condition do I have to apply to U and p, since the flow needs to go though undisturbed..... Regards and Thanks, Frank Regard, Frank
Frank Bos |
HELP NEEDED HOW TO MAP VALUES FROM PATCH OF ONE MESH TO PATCH OF ANOTHER MESH | mkraposhin | OpenFOAM Running, Solving & CFD | 3 | September 4, 2011 09:42 |
domain interface for moving and deforming mesh | chetan mundhe | CFX | 1 | December 2, 2007 16:27 |
moving mesh grid interface | Dieter | FLUENT | 6 | March 23, 2006 06:54 |
VOF+patch+irregular interface shape | luckyluke | FLUENT | 0 | May 23, 2005 20:52 |
Moving interface | Unal | FLUENT | 4 | April 16, 2004 10:02 |
