Really weird problem could nbt figure it out
Old   December 29, 2007, 05:17
Default THE PROBLEM MAY BE SIMPLE, BUT
kalaiselvan
21kalee is on a distinguished road
THE PROBLEM MAY BE SIMPLE, BUT I COULDN'T FIGURE IT OUT.
Create mesh for time = 0
Reading thermodynamicProperties
Reading transportProperties
Reading field p
Reading field T
Calculating field e from T
Reading field U
Starting time loop
Time = 1e-05
Courant Number mean: 0 max: -0
--> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::emptyFvPatchField<double>::updateCoeffs()
#3 Foam::fvPatchField<double>::evaluate()
#4 Foam::GeometricField<double,>::GeometricBoundaryFi eld::evaluate()
#5 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::surfaceIntegrate<double>(Foam::Geometri cField<double,> const&)
#6 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::div<double>(Foam::GeometricField<double ,> const&)
#7 main
#8 __libc_start_main
#9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
From function emptyFvPatchField<type>::updateCoeffs()
in file fields/fvPatchFields/basicFvPatchFields/empty/emptyFvPatchField.C at line 139.
FOAM aborting
21kalee is offline   Reply With Quote
Old   December 29, 2007, 08:48
Default empty b.c. can only be used fo
Mattijs Janssens
mattijs is on a distinguished road
empty b.c. can only be used for 1D or 2D geometry. In simple terms your mesh has be createable by extrusion. Front and back then can be empty but it is up to you to guarantee no flow/pressure gradient in that direction. See the lid-driven tutorial as an example.
mattijs is offline   Reply With Quote
Old   December 30, 2007, 10:30
Default Thanks, It really helped and i
kalaiselvan
Thanks, It really helped and i had fixed the problem
Weird problem with engineFoam tutorial chris1980 OpenFOAM Running, Solving & CFD 29 August 28, 2013 06:53
Line/Rake - Weird Problem Marc FLUENT 6 August 8, 2007 14:15
Airfoil 2D, very weird result Martin FLUENT 4 June 13, 2007 12:21
figure rati FLUENT 4 July 17, 2006 06:18
Getting rid of weird Tet regions in ICEM? Chebeba CFX 8 June 14, 2006 17:49
