December 30, 2007, 15:55 |
Hi all,
As I'm learning a
Michael Jaworski
Rep Power: 17 |
Hi all,
As I'm learning a lot of stuff lately, I hope you'll have some patience with me on this. I have gotten the 1.4.1-dev version install on my machine and was going through the different solvers making sure they all worked. I ran across a problem with sonicFoam which I managed to fix, but I don't understand and it's the understanding which I would like. When running the tutorial case, forwardStep, I would get the following error: *************************************** --> FOAM FATAL IO ERROR : keyword laplacian((rho*(1|A(U))),p) is undefined in dictionary "/<path>/system/fvSchemes::laplacianSchemes" file: /<path>/system/fvSchemes::laplacianSchemes from line 47 to line 50. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 154 FOAM exiting ******************************** Now, I fixed it by changing the fvSchemes file to include: laplacianSchemes { default Gauss linear corrected; \\ was none laplacian(mu, U) Gauss linear corrected; laplacian(mu, e) Gauss linear corrected; laplacian((rho*(1.0|A(U))),p) Gauss linear corrected; } Now, this worked, but originally I had figured that the problem lay in last laplacian((rho*...) term. Looking in the source code for sonicFoam.C, I found a laplacian term for a (rho*rUA, p), but none for this weird 1.0|A(U) thing. So my questions are these: what does laplacian((rho*(1.0|A(U))), p) mean since I don't know what the pipe (|) command does and it doesn't seem to be in the manual (or I'm not looking for it correctly) and, bigger picture, what does this mean for the solver/future solvers. When I attempted to change the laplacian in fvSchemes to (rho*rUA, p) it didn't work, but this is the term in the source code. So, if someone can help my confusion, I'd greatly appreciate it. Regards, Mike J. |
OscillatingFixedValue in OpenFOAM 141dev | mathieu | OpenFOAM Bugs | 27 | July 6, 2016 23:24 |
OscillatingFixedValue in OpenFOAM 141dev | mathieu | OpenFOAM Bugs | 0 | September 9, 2008 17:50 |
141dev svn repository | egp | OpenFOAM Installation | 1 | August 25, 2008 16:10 |
SonicFoam | stvtiegh | OpenFOAM Running, Solving & CFD | 1 | June 26, 2008 09:30 |
Help me with sonicFoam | marcelo | OpenFOAM Running, Solving & CFD | 6 | December 10, 2005 02:57 |
