December 29, 2007, 05:17 |
THE PROBLEM MAY BE SIMPLE, BUT
kalaiselvan
THE PROBLEM MAY BE SIMPLE, BUT I COULDN'T FIGURE IT OUT.
Create mesh for time = 0 Reading thermodynamicProperties Reading transportProperties Reading field p Reading field T Calculating field e from T Reading field U Reading/calculating face flux field phi Starting time loop Time = 1e-05 Courant Number mean: 0 max: -0 --> FOAM FATAL ERROR : This mesh contains patches of type empty but is not 1D or 2D by virtue of the fact that the number of faces of this empty patch is not divisible by the number of cells.#0 Foam::error::printStack(Foam:stream&) #1 Foam::error::abort() #2 Foam::emptyFvPatchField<double>::updateCoeffs() #3 Foam::fvPatchField<double>::evaluate() #4 Foam::GeometricField<double,>::GeometricBoundaryFi eld::evaluate() #5 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::surfaceIntegrate<double>(Foam::Geometri cField<double,> const&) #6 Foam::tmp<foam::geometricfield<double,> > Foam::fvc::div<double>(Foam::GeometricField<double ,> const&) #7 main #8 __libc_start_main #9 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122 From function emptyFvPatchField<type>::updateCoeffs() in file fields/fvPatchFields/basicFvPatchFields/empty/emptyFvPatchField.C at line 139. FOAM aborting |
December 29, 2007, 08:48 |
empty b.c. can only be used fo
Mattijs Janssens
Rep Power: 26 |
empty b.c. can only be used for 1D or 2D geometry. In simple terms your mesh has be createable by extrusion. Front and back then can be empty but it is up to you to guarantee no flow/pressure gradient in that direction. See the lid-driven tutorial as an example.
December 30, 2007, 10:30 |
Thanks, It really helped and i
kalaiselvan
Thanks, It really helped and i had fixed the problem
Weird problem with engineFoam tutorial | chris1980 | OpenFOAM Running, Solving & CFD | 29 | August 28, 2013 06:53 |
Line/Rake - Weird Problem | Marc | FLUENT | 6 | August 8, 2007 14:15 |
Airfoil 2D, very weird result | Martin | FLUENT | 4 | June 13, 2007 12:21 |
figure | rati | FLUENT | 4 | July 17, 2006 06:18 |
Getting rid of weird Tet regions in ICEM? | Chebeba | CFX | 8 | June 14, 2006 17:49 |
