Turbulence Modells - Overview
Old   June 21, 2009, 02:59
Default Turbulence Modells - Overview
BastiL
bastil is on a distinguished road
Dear FOAMers,
I am currently doing some turbulence modeling benchmark. I miss some overview list about turbulence models in the documentation as it has been availabele in former releases I think.
Looking at the source code I see there is a kOmega SST model (I think it came with 1.4.1) but I don't know if this is a high-reynolds (wall-function) or a low-reynolds implementation? Are there some documents about that?
Thanks BastiL
bastil is offline   Reply With Quote
Old   June 22, 2009, 11:33
Paulo Alexandre Costa Rocha
paulo is on a distinguished road
Hi BastiL,
You can find some discussion on this topic here:
http://www.cfd-online.com/Forums/ope...-overview.html
Best Regards,
Paulo Rocha
paulo is offline   Reply With Quote
Old   June 22, 2009, 15:48
BastiL
Thanks paulo - however the link is linking to this thread?
Regards BastiL
Old   June 23, 2009, 07:55
Red face I'm sorry
Hi BastiL,
I hope this link is correct:
http://www.cfd-online.com/Forums/ope...tallmaras.html
Sorry again.
Best Regards,
Paulo Rocha
Old   April 19, 2010, 17:18
Jade M is on a distinguished road
For accurate boundary layer predictions, such as separation prediction, then the SST model should be used with y+<2. In this case, the SST model switches to a low-Re formulation near the wall rather than the wall function formulation. SST still works with 11<y+<300, but the results will be fairly similar to the k-e model since wall functions are used. For 2<y+<11, SST blends wall functions and low-Re formulations. In some situations, such as when needing accurate boundary layer heat transfer predictions or when using the transition model, an even lower y+ of about 1 is recommended with the SST model.
Jade M is offline   Reply With Quote
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 04:30
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
turbulence modells pXYZ Main CFD Forum 1 April 13, 2006 06:24
