September 17, 2007, 14:45 |
Often after the simulation has
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Often after the simulation has started, I find that the minimum volume fraction for a certain phase has a negative value which I guess comes from using the limitedLimitedLinear scheme. For instance, here is a transcript of the log file:
Courant Number mean: 0.0003676463941223166 max: 0.1433804123149916 deltaT = 5.902777777777798e-05 Time = 0.01246875 smoothSolver: Solving for alphawater, Initial residual = 5.367012678397666e-07, Final residual = 1.657007202694921e-09, No It erations 1 water volume fraction, min, max = 0.500000013666753 -2.476129830158727e-05 1.000241328781609 smoothSolver: Solving for alphaoil, Initial residual = 0.0005141524902777194, Final residual = 1.115623990538466e-09, No Iter ations 3 oil volume fraction, min, max = 0.001774934415791225 -0.0002436711866175406 1.000002660725418 air volume fraction, min, max = 0.4982250519173831 -0.0001213547565864747 1.000021713925952 Is there a way to prevent negative volume fractions such as -0.0002436711866175406 and -0.0001213547565864747 by using a different scheme? Or would grid refinement cause the problem to go away? My current fvSchemes file reads: ddtSchemes { default Euler; } gradSchemes { default Gauss linear; grad(U) Gauss linear; grad(gamma) Gauss linear; } divSchemes { div(rho*phi,U) Gauss upwind; div(phi,alpha) Gauss limitedLimitedLinear 1.0 -0.00001 1.00001; div(phic,alpha) Gauss interfaceCompression; //upwind; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default yes; } |
MultiphaseInterFoam | virginie_e | OpenFOAM Running, Solving & CFD | 1 | July 21, 2009 03:37 |
Possible bug in multiphaseInterFoam | msrinath80 | OpenFOAM Bugs | 16 | March 25, 2008 20:09 |
Problems with tutorialcase multiphaseInterFoam damBreak4phaseFine | jfb | OpenFOAM Bugs | 2 | February 29, 2008 06:20 |
MultiphaseInterFoam damBreak4phaseFine case | hsieh | OpenFOAM Installation | 3 | April 12, 2007 19:50 |
DPM question | lee | FLUENT | 0 | September 5, 2004 21:06 |
