January 31, 2006, 14:37 |
HI,
I need your help once aga
olivier Petit
Rep Power: 17 |
HI,
I need your help once again :-) when I make turbulence "on" in bubbleColumn example for twoPhaseEulerFoam solver I have a divergence quickly. I thought that the problem comes from turbulence model, so I try the model proposed by Sato and Sekoguchi (1975) . the result is the same (divergence).. Can someone tell me what is the problem ? NB: I tried the different Schemes |
February 2, 2006, 23:00 |
Dear all,
Can someone tell m
olivier Petit
Rep Power: 17 |
Dear all,
Can someone tell me what is the problem with turbulence in twoPhaseEulerFoam. I changed the bubbleColumn example with another one, the result without turbulence is correct bat when I active the turbulence (with k-epsilon or k-epsilon modified proposed by Sato) the problem is almost the same, it appears immediately. I patch in the inlet k and epsilon like that: k=3/2(Uref I) epsilon=Cmu^(3/4) * k^(3/2)/(0.07*dinlet) (ref: H.K VERSTEEG & W MALALASEKERA) thank you |
September 11, 2007, 16:37 |
I have the same problem
I have the same problem... Has nobody a solution? regards Holger
Holger Marschall web: http://www.holger-marschall.info mail: holgermarschall@yahoo.de |
RSM do not converge | Eric Wang | CFX | 3 | January 13, 2009 03:31 |
coupled solver wont work in star ccm+ | richie | Siemens | 5 | November 4, 2008 04:51 |
K-eps what should converge first? what last? | Nick | FLUENT | 1 | May 2, 2007 06:52 |
My Solution wont Converge!!! | Chris | FLUENT | 6 | April 16, 2005 18:57 |
why it can not converge | apple | FLUENT | 21 | July 16, 2001 03:18 |
