July 31, 2007, 07:17 |
I have a problem with the patc
Radu Mustata
I have a problem with the patch in the subject...as in if I am using the rhoExplicitPorousSimpleFoam and its angledDuct tutorial, it works fine. When I am trying to use it into another application written by my humble self it does not work anymore, although I have (apparently) the same includes in the main and options in Make., i.e.
#include "fixedGradientFvPatchFields.H" and in options: ... EXE_INC = \ -I$(LIB_SRC)/finiteVolume/cfdTools \ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/turbulenceModels \ -I$(LIB_SRC)/transportModels EXE_LIBS = \ -lfiniteVolume \ -lmeshTools \ -lincompressibleTurbulenceModels \ -lincompressibleTransportModels I guess it has nothing to do with compressible/incompressible libs...right? Any ideas? Thanx, Radu |
August 1, 2007, 06:14 |
Still cannot figure out
Radu Mustata
Still cannot figure out what is happening. Now all my options and includes are incorporate the options and includes of rhoExplicitPorousSimpleFoam and still it says: Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 0.574894, Final residual = 0.0244085, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.115229, Final residual = 0.00483646, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.178315, Final residual = 0.00161697, No Iterations 76 DICPCG: Solving for p, Initial residual = 0.00321388, Final residual = 2.98041e-05, No Iterations 60 DICPCG: Solving for p, Initial residual = 0.000109443, Final residual = 9.69371e-07, No Iterations 75 DICPCG: Solving for p, Initial residual = 8.9062e-06, Final residual = 9.87235e-07, No Iterations 21 time step continuity errors : sum local = 1.77364e-06, global = -4.28777e-08, cumulative = -4.28777e-08 DILUPBiCG: Solving for epsilon, Initial residual = 0.0381206, Final residual = 0.00206035, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0154824, No Iterations 2 --> FOAM FATAL ERROR : Unknown patchTypefield type turbulentIntensityKineticEnergyInlet Valid patchField types are : 25 ( fixedGradient symmetryPlane directMapped oscillatingFixedValue turbulentInlet freestream default empty fixedValue uniformFixedValue cyclic mixed processor calculated slip timeVaryingMappedFixedValue timeVaryingUniformFixedValue directionMixed sliced partialSlip outletInlet inletOutlet wedge zeroGradient waveTransmissive ) From function fvPatchField<type>::New(const word&, const fvPatch&, const Field<type>&) in file lnInclude/newFvPatchField.C at line 59. FOAM exiting Any ideas of how to fix this? Cheers, Radu |
September 18, 2009, 12:33 |
Steve Hansel
Are you using an old version of OpenFOAM?
September 19, 2009, 03:56 |
Gijsbert Wierink
Rep Power: 18 |
Hi Radu,
Did you manage to fix the problem? It smells like the wrong boundary condition. Regards, Gijs |
TurbulentIntensityKineticEnergyInlet problem with turbulenceR | nico765 | OpenFOAM Running, Solving & CFD | 2 | July 6, 2009 10:07 |
