July 11, 2007, 13:14 |
Consider a 3D rectangular chan
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Consider a 3D rectangular channel of still water and at time t = 0 sec, a 3D air bubble rises from the bottom. The simulation completed nicely with interFoam. How can I visualize the bubble rising in water in paraView? Is there any way to separate cells based on density as opposed to gamma? I would prefer to see a sharp distinction. How do you postprocess 3D interFoam cases?
July 11, 2007, 13:21 |
How about drawing an iso-surfa
Hrvoje Jasak
Rep Power: 33 |
How about drawing an iso-surface of gamma = 0.5?
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
July 11, 2007, 13:59 |
That did the trick. Thanks Hrv
Rep Power: 21 |
That did the trick. Thanks Hrv! I suspect it was the same way you created that animation of air being injected from a tube into a water tank with a free surface.
July 11, 2007, 15:03 |
Hrv: I thought you might want
Rep Power: 21 |
Hrv: I thought you might want to look at a sample movie (two large diameter bubbles breaking up in a 3D tank completely filled with water) visualized using gamma isosurface = 0.5. I used OpenFOAM 1.4 and Bernhard's excellent funkySetFields utility to initialize gamma. Here it is:
http://www.ualberta.ca/~madhavan/isosurface_movie.mpg Once again, thanks for your help |
Display Modes | |
Visualization | Bharath | FLUENT | 2 | November 11, 2002 18:00 |
Need help on visualization | Sujit Kirpekar | Main CFD Forum | 1 | October 7, 2002 05:31 |
AMR Visualization | Dawei Sun | Main CFD Forum | 1 | June 27, 2002 02:12 |
CFD Visualization | Chan Keen Ian | Main CFD Forum | 1 | December 29, 2001 03:49 |
3d visualization | Maciej Matyka | Main CFD Forum | 0 | July 11, 2001 11:51 |
