Obtain PointLabels from code
Old   June 19, 2007, 12:27
Default Hello out there, I need two
bfa
Björn Fabritius
bfa is on a distinguished road
Hello out there,
I need two things to be done, and somehow don't manage to do it:
1) How can I get the ID of a patch by name (I tried findPatchID, but it doesn't work on a fvMesh)?
2) How can I get the labels of the points belonging to this patch?
by the way: the search function in my doxygen representation is broken and it's quite hard to guess the right class if i want to find a specific function. Is that a known issue or am I alone with this problem?
thanks for your guidance
Bjoern
bfa is offline   Reply With Quote
Old   June 19, 2007, 12:50
Default Hi Björn! The answer to the f
Francesco Del Citto
fra76 is on a distinguished road
Hi Björn!
The answer to the first question should be:
label patchI = mesh.boundaryMesh().findPatchID("patchname");
Regarding the second question, I don't know exactly how to access the point, but with this line you can access the faces centers:
const fvPatchVectorField& faceCentres = mesh.Cf().boundaryField()[patchID];
For the point, perhaps something like:
const fvPatchVectorField& faceCentres = mesh.points().boundaryField()[patchID];
But I've never tried it...
fra76 is offline   Reply With Quote
Old   June 19, 2007, 13:09
Default You can get all the point labe
Eugene de Villiers
eugene is on a distinguished road
You can get all the point labels on a patch via:
const labelList listOfPatchPointLabels mesh.boundaryMesh()[patchID].meshPoints();
Check:
src/OpenFOAM/lnInclude/PrimitivePatch.H and polyPatch.H for the members of polyPatch (i.e. mesh.boundaryMesh()[patchID]).
eugene is offline   Reply With Quote
Old   June 19, 2007, 14:08
Default thanks a lot to both of you!
bfa
Björn Fabritius
it worked just fine
Old   June 19, 2007, 15:25
Default The search function in the dox
Alberto Passalacqua
The search function in the doxygen documentation requires you install the documentation on a web server with php enabled.
Regards,
Alberto
Alberto Passalacqua
UDF: how to obtain the neighbor face? Benlong FLUENT 0 May 25, 2007 09:36
how to obtain streamline profile for 3d Frank FLUENT 1 February 2, 2006 04:01
How to obtain forces Karimu FLUENT 2 August 22, 2005 18:26
How to obtain.... Sharad Dugad FLUENT 6 February 13, 2002 13:14
how to obtain a profile ... olivier FLUENT 2 December 13, 2001 07:21
