Only Stockes
Old   June 11, 2007, 06:39
Default Hi all, I need to know if a
lam
Hoang-Lam
lam is on a distinguished road
Hi all,
I need to know if anybody has already implemented a simple Stockes equation? (without the non-linear term)
Lam
lam is offline   Reply With Quote
Old   June 11, 2007, 16:34
Default Check out potentialFoam. An
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Another related discussion thread: http://www.cfd-online.com/OpenFOAM_D...es/1/2765.html
msrinath80 is offline   Reply With Quote
Old   June 11, 2007, 16:45
Default My Apologies. potentialFoam is
My Apologies. potentialFoam is the opposite of what you want. Check that other thread instead.
Old   June 12, 2007, 03:22
Default Hi pUIl, Thank you to reply
lam
Hoang-Lam
Hi pUIl,
Thank you to reply me.
Indeed, I think taht I found how to have a simple Stockes:
I removed "div(phi,U)" term in the simpleFoam.
Of course, I made it after studying precisely the code with DoxyGen.
I'm quite sure that I have my STOCKES solver, now.
Hope that somebody does tell me if I'm wrong.
Cheers,
Lam
Old   June 12, 2007, 03:28
Default Do a quick validation. Stokesi
Do a quick validation. Stokesian flow past a fixed sphere. There are analytical expressions you can compare your numerical results with.
Old   June 12, 2007, 05:42
Default Hi pUII, Thnaks to give thi
lam
Hoang-Lam
Hi pUII,
Thnaks to give this information.
I've tried to find the ananlytical expression but I've not found it.
Can you tell in which paper I can find it?
THanks in advance pUII,
Lam
Old   June 12, 2007, 05:50
Default Compare your velocity/pressure
Compare your velocity/pressure fields with any of the analytical expressions[1,2]. Alternately, you could try using the liftDrag utility to estimate the net drag force on the sphere and compare it with the usual expression:
Fd = 6 * pi * dynamic viscosity * radius * free_stream_velocity
[1] http://scienceworld.wolfram.com/phys...lowSphere.html
[2] http://web.mit.edu/fluids-modules/ww.../2-5Stokes.pdf
Old   June 12, 2007, 08:38
Default Ok, pUII! I think this the
lam
Hoang-Lam
Ok, pUII!
I think this the right way to check.
Thanks again.
My best cheers,
Lam
FoamUser and steady STOCKES Lam Main CFD Forum 0 June 8, 2007 04:20
