Rotating boundary simplefoam
Old   May 31, 2007, 10:01
Default Is there an easy way to make r
Gabriel Barroso
gabriel is on a distinguished road
Is there an easy way to make rotating wall boundary conditions? I have an outlet which is rotating and it would be very elegant if the boundary could be set as in the cavity tutorial with a constant velocity but in tangential direction.
Bests, Gabriel
gabriel is offline   Reply With Quote
Old   May 31, 2007, 10:09
Default Gabriel, I don't know if it
rswbroers
Gabriel,
I don't know if it will work on an outlet b.c., but you can see here http://www.cfd-online.com/OpenFOAM_D...es/1/4473.html how to create a rotating wall boundary condition.
Good luck!
best regards,
Roland
Old   May 31, 2007, 10:21
Default You "just" have to loop on the
Francesco Del Citto
fra76 is on a distinguished road
You "just" have to loop on the patch and assign, for each file, a different velocity vector, computed in the proper way.
If you don't need something very general, it's enough to modifiy the standard solver (i.e. simpleFoam) and set ther the velocitis before the time loop.
If you want something more general, you have to write some more code, and handle for example dictionary files for specifying rotating patches and velocities, etc...
For example:
vector axis; /* To be defined as rotation axis */
vector center; /* To be defined as center of rotation */
scalar omega; /* Rotation speed */
label patchID=mesh.boundaryMesh().findPatchID("rotating_ patch");
fvPatchVectorField& wU = U.boundaryField()[patchID];
const fvPatchVectorField& faceCentres = mesh.Cf().boundaryField()[patchID];
forAll(wU, faceI)
vector c1 = faceCentres[faceI]; /* You probably need it */
wU[faceI] = (axis*omega) ^ (c1 - center);/* Your velocity law ... */
I cannot assure that this code works as it is, but the idea should be correct.
Have fun!
Francesco
fra76 is offline   Reply With Quote
Old   June 1, 2007, 06:13
Default Hi there, I just would like
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi there,
I just would like to continu the topic there without any answer for Gabriel (sorry) but with other questions ...:
1- what's the difference between your link, Roland (uniformAxialRotation for exemple) and the swirl inlet condition avaiable with OF engineSwirl ?
2- in OF V 1.3, we have to copy the piece of code in OpenFOAM-1.3/applications/utilities/preProcessing and then compiling with wmake or .....not (copy on an other file ...)?
thanks for replying,
Cedric
cedric_duprat is offline   Reply With Quote
Old   June 4, 2007, 03:41
Default Cedric, I have never used t
rswbroers
Cedric,
I have never used the swirl inlet condition or engineSwirl, so I really can't comment on any differences with the code that I am using.
As for your second question, I am not quite sure what you mean.
To use uniformAxialRotation in simpleFoam I copied it to the simpleFoam directory, added the line
uniformAxialRotation/uniformAxialRotation.C
to simpleFoam/Make/files and then did 'wmake' in thi simpleFoam directory.
I hope this answers your question.
best regards,
Roland
Own boundary condition modified simpleFoam erorr in parallel execution sponiar OpenFOAM Running, Solving & CFD 1 August 27, 2008 09:16
Define non uniform TKE boundary condition in simpleFOAM qtian OpenFOAM Running, Solving & CFD 9 July 30, 2007 14:54
SimpleFoam boundary conditions changed in OF 14 adorean OpenFOAM Running, Solving & CFD 5 June 22, 2007 07:50
Rotating boundary eros CFX 5 May 16, 2007 18:09
SimpleFoam boundary conditions hani OpenFOAM Running, Solving & CFD 2 January 10, 2007 02:44
