May 3, 2007, 05:56 |
I need some help fr
Hoang-Lam
I need some help from you. I use the simpleFoam solver with laminar flow, and turbulence off. And my geomtries are converted by gmsh2ToFoam. But each time, I make a computation on a complexe geometrie, checkMesh tells me that I have a lot faces which have a "Severe non-orthogonality" (but it's said finally: "Non-orthogonality check OK.") so I do not care (should I?). But I really get worried about the rate of "Max skewness" which is about 2000% (and more for the other meshes I have)!! checkMesh says to me "This may impair the quality of the result." And each time, my computation failed (the sum local, and the p initial residual went off!) And of course, I can not improve the quality of my meshes before doing the conversion into Foam. My question: is how can I try to use Finit Element discretisation, instead of Finite Volume discretisation in Foam? I think I need something like "fvSchemes" dictionnary but for Finite Element, isn't it? (I do not know if it may improve my computation, but I really want to try to use it. ) Thanks in advance, Lam |
skewness | chouki | FLUENT | 0 | September 4, 2007 10:41 |
skewness | Donia | FLUENT | 1 | June 1, 2007 14:05 |
skewness | sam | FLUENT | 2 | March 6, 2007 23:26 |
must improve skewness ? | mario | FLUENT | 4 | January 31, 2007 09:10 |
Skewness | Taskin | FLUENT | 5 | April 6, 2005 15:21 |
