Inhomogenous two fluid model with mixing fluids
Old   January 8, 2007, 12:09
Default Hi all, is there any solver
Volker Kaufmann
vkaufmann is on a distinguished road
Hi all,
is there any solver which can handle mixing fluids calculating a velocity field for each phase? Means something like bubbleFoam but without the restriction of one phase to be disperse. In twoLiquidMixingFoam a homogeneous approach seems to be implemented, right?
If there's no solver, how is this restriction in bubbleFoam implemented or is it possible to modify twoLiquidMixingFoam in an appropriate way?
Thanx a lot in advance.
Volker
vkaufmann is offline   Reply With Quote
Mixing different fluids Isabel FLUENT 1 October 22, 2010 16:53
mixing two fluids using mixture model fadhil FLUENT 0 June 9, 2008 01:28
Mixing two fluids Rajat FLUENT 3 January 21, 2007 19:19
Inhomogeneous two fluid model with mixing fluids vkaufmann OpenFOAM Running, Solving & CFD 4 January 8, 2007 14:44
Inhomogenous two fluid model with mixing fluids vkaufmann OpenFOAM Running, Solving & CFD 0 January 8, 2007 12:12
